Stance
Will_H#24
Levittown Pa.
What can I do to make my car have this stance without going to air shocks?
Jacked up rear ends were the result of big tires and not having the capability to narrow the rear end . It throws your weight distribution and steering angles off . My dart handles nice , drives straight and stable as well as launches really well even with 500+ hp and torque.
Interesting thing happened today. I had to drive my Barracuda 40 miles (each way) to pick up some 15” steel wheels I scored ( will do a seperate post on them ) and 3 of the 4 had big truck tires mounted on them making them pretty heavy . I loaded them in back of my Barracuda and to my surprise it handled and drive much better on return trip !
I have Mancini HD springs on the back which raise the rear end ever so slightly ( after break in ) and I think I installed the Moog offset control bushings as per the instructions ( backwards) so I couldn’t get the caster and camber numbers I wanted which makes the car feel very light and wandery in front . That will be fixed when I pull the engine/trany this winter to install the 46rh I had built.
Not to mention installing the 15 x 6 1/2 steel rims I scored !
