1. dartlove
    dartlove Well-Known Member
    181
    34
    May 5, 2013
    northern Ca
    Local Time:
    6:42 PM
    Need to find a starter. Engine has 14: 1 compression. What are the best options. What are you guys using?
  2. yellow rose
    yellow rose Doctor of Thinkology.
    17,554
    13655
    Jun 19, 2015
    Living on the razors edge
    Local Time:
    6:42 PM
    I use a stock Chrysler starter. You can find them on Amazon and eBay for under 70 bucks.
    • Agree Agree x 1
    • moparmat2000
      moparmat2000 FABO Gold Member FABO Gold Member
      13,895
      3645
      May 13, 2010
      Grand Tetons
      Local Time:
      8:42 PM
      Chrysler mini hi torque Denso. 1.87 HP out of compact 8lbs. Great w headers. See post #13, and #16
      • Agree Agree x 2
      • yellow rose
        17,554
        13655
        Jun 19, 2015
        Local Time:
        6:42 PM
        I should have been more clear. I meant current, small starter. Not the old, giant, 95 pound hunk of crap starter that came on the earlier stuff.
        I meant mini starter. I always think when talking about a 14:1 engine it won't use that big, clunky starter. But I should have been more clear.
      • Cudafever
        Cudafever Well-Known Member
        3,055
        592
        Sep 27, 2009
        Local Time:
        7:42 PM
        I'm running 12.8 compression and it don't car one bit!
      • moparmat2000
        13,895
        3645
        May 13, 2010
        Grand Tetons
        Local Time:
        8:42 PM
        Mopar mini denso off any magnum 3.9V6 5.2V8 or 5.9V8 will work just fine. I grabbed 2 at my local boneyard for $20 each off the starter motor shelf. Both were remanned recently still had stickers and fresh paint on them.
        • Like Like x 1
        • j par
          j par Well-hung Member
          14,882
          7095
          Jul 2, 2014
          Portland Oregon
          Local Time:
          6:42 PM
          Some of these boneheads on this forum don't think I listen to them because I'm busting their nuts all the time, but definitely some good advice was to go down to the wrecking yard and go find a truck like my truck and pull the starter out of it. I took it home and sprayed and wiped it with WD-40 three times and it came out looking like new. Now my 73 duster starts just like my 98 truck...
          Perfect and fast every time...
          Edit, $22 with environmental fee...
          • Like Like x 2
          • j par
            14,882
            7095
            Jul 2, 2014
            Portland Oregon
            Local Time:
            6:42 PM
            That $79 remand parts store mini starter gave me trouble until it finally died...
          • 318willrun
            318willrun Stomper 4x4... we kept energizer in business
            9,479
            8402
            Sep 13, 2013
            I'm here
            Local Time:
            8:42 PM
            I usually buy one for a mid 90's Dakota. Used or New, Never an issue.
            • Like Like x 2
            • Agree Agree x 1
            • j par
              14,882
              7095
              Jul 2, 2014
              Portland Oregon
              Local Time:
              6:42 PM
              Speak of the devil LOL...
            • 318willrun
              9,479
              8402
              Sep 13, 2013
              I'm here
              Local Time:
              8:42 PM
              Somebody besides me told you to do that, because if I would have said it, you'd never had done it.... until you called two professionals and a moderator.. :poke:
              • Like Like x 1
              • Agree Agree x 1
              • Disagree Disagree x 1
              • Cudafever
                3,055
                592
                Sep 27, 2009
                Local Time:
                7:42 PM
                X2
                Mine was from Napa. works great.
              • mopardude318
                mopardude318 Well-Known Member
                9,503
                607
                Jan 7, 2005
                Gilroy, Ca
                Local Time:
                6:42 PM
              • mopardude318
                9,503
                607
                Jan 7, 2005
                Gilroy, Ca
                Local Time:
                6:42 PM
                dbl post
              • Johnny Mac
                Johnny Mac www.blueprintengines.com FABO Vendor
                2,795
                1504
                Jul 10, 2010
                OHIO
                Local Time:
                9:42 PM
                No idea a hemi era starter still fit an old school mopar? Any benefit vs the "normal" mopar mini?
                Very cool!
                • Agree Agree x 1
                • moparmat2000
                  13,895
                  3645
                  May 13, 2010
                  Grand Tetons
                  Local Time:
                  8:42 PM
                  The snout on the 5.7 manual starter looks like the older "big dawg 2 ton tessies" that everybodies pulling off. Bolt pattern looks the same too. 1.7KW 2.28HP isnt too shabby either Not many of em if any have hit my local boneyards yet. That's why I went with the mini denso. Plentiful, inexpensive, durable, powerful, light weight, tiny. 1.4KW 1.87 HP about as much HP as a stock monster sized 60s-70s big block starter. Only thing that seems to go bad w the denso over time is the solenoid contactor. Easy fix, rock auto has the contactor parts for cheap.
                  Dartlove might actually benefit more though from using a 5.7 manual trans starter since he has a 14.1 compression V8. The 5.7 hemi starter has more HP than the dakota/ram starter. 2.28 HP vs 1.87 HP
                  Thanks mopardude318 for bringing that to the table.
                  • Like Like x 1
                  • Thanks! Thanks! x 1
                  • mopardude318
                    9,503
                    607
                    Jan 7, 2005
                    Gilroy, Ca
                    Local Time:
                    6:42 PM
                    The starter from an 05-08 Ram with 5.7 and a manual trans is physically smaller then all the rest of the common mini starters because it is a coaxial starter—the motor axis is the same as the drive axis—which makes it more compact than the regular mini starters, which are offset starters. (The motor axis is outboard of drive axis).
                    Unlike the other starters, this one has one of its 2 mounting holes threaded. Drill out the threaded hole so it’s plain.
                    • Like Like x 2
                    • moparmat2000
                      13,895
                      3645
                      May 13, 2010
                      Grand Tetons
                      Local Time:
                      8:42 PM
                      I really like it. How do these hold up over the long run compared to a mini denso though? I mean a mini denso spins em over with some authoriy, and is pretty reliable and inexoensive. These 5.7 hemi starters may just be the bees knees from a size and HP standpoint. Looks similar to the old Delco Remys Problem I have on my end is finding one out by me yet. Eventually Hemi trucks will hit the boneyard here. Looking like a stick shift one is gonna be hard to find though. Seems everybody these days wants an effin slushbox.
                    • yellow rose
                      17,554
                      13655
                      Jun 19, 2015
                      Local Time:
                      6:42 PM
                      Well, now I have to go buy another starter!! I love the looks of that. Just need to make sure it will actually clear my headers.
                      • Like Like x 1
                      • Johnny Mac
                        2,795
                        1504
                        Jul 10, 2010
                        OHIO
                        Local Time:
                        9:42 PM
                        Awesome description and pics. Thanks! As long as the solenoid doesn't interfere with headers...seems like a win win
                        • Like Like x 1
                        • moparmat2000
                          13,895
                          3645
                          May 13, 2010
                          Grand Tetons
                          Local Time:
                          8:42 PM
                          If the denso mini will clear, then this thing will for sure. Look at the pix
                        • moparmat2000
                          13,895
                          3645
                          May 13, 2010
                          Grand Tetons
                          Local Time:
                          8:42 PM
                          Just found em new on evilbay for between $63-$68. Not sure how good these are
                          • Like Like x 1
                          • mopardude318
                            9,503
                            607
                            Jan 7, 2005
                            Gilroy, Ca
                            Local Time:
                            6:42 PM
                            Thanks goes to slantsixdan. He recommends the Remy remans, which go for about a buck twenty.
                          • yellow rose
                            17,554
                            13655
                            Jun 19, 2015
                            Local Time:
                            6:42 PM
                            Looking at the pictures, it doesn't look like the clock exactly the same. It's a bit hard to tell in the picture, but I'm looking at the opening for the gear. Looking at that, the two starters appear to be laying at the same angle.
                            If so, my headers will be really close to that starter. If not hitting it.
                            • Agree Agree x 1
