moparmike98
Last Friday I went to start it up and it struggled a little more than usual but I didn't think anything of it because it's getting colder. But halfway down the driveway it shut down and all my lights when out like the battery was dead. It wouldn't even try to turn over like the key wasn't even being turned. I got out and there was a slight burning/smoking smell. Then that night it started right up like nothing happened, I didn't drive it or run it long I was only checking if it would start. Monday came around and I started it up and the same thing as Friday happened again but this time when I pushed it to the garage it started and I drove in. Now it won't even start it gave a small little blurp of cranking (this time I had the hood up) then I saw smoke coming from down by the starter or that area jumped out and disconnected the battery. I can't figure out what it was, I can't see burnt wires. Also when disconnecting the battery the positive and ground wires were hot. Please help
