rmchrgr
Skate And Destroy
Decided to put my steel crank, 318 short block and set of '302' casting heads up for sale.
Here's the specs on the short block. Block itself is a '67 casting. Steel crank, stock rods, factory flat top pistons with four valve reliefs. (Probably from a truck) Block has new freeze plugs, new bearings and rings. Was hot tanked and had the new bearings and rings installed but that was it, no overbore etc. There is still a ridge at the top of the cylinder.
Heads are the famous '302' castings from the mid '80s. I believe these are from '86. Heads are complete - valves, springs, keepers, retainers, rocker arms, shafts, hold downs and fasteners. They will need to be cleaned up.
Would rather not separate, this is a package deal. I'd also rather not deal with shipping these parts but if you're willing to make the arrangements and pay for it, then I'm willing to help facilitate it. Parts are located in Huntington, NY on Long Island. If you're local, come take a look.
Cash is best, money order works great too. Personal check is fine but parts will not be released/shipped until it clears. I will accept Paypal but please add 4% to the final total for fees.
I also have an Edelbrock LD4B intake that I would be willing to include for an extra $150.
Asking $450 for everything. $600 with the LD4B.
PM with any questions. Pics below. - Greg
