[SOLD] Steel dual valve spring retainers, used
physixx
Edison, NJ
I have for sale a very nice, clean used set of steel dual valve spring retainers. They are for 1.50-1.55”” diameter valve springs with the inner spring outside diameter of 1.115”, center hole diameter is .415”, uses 7 degree keepers and 3/8” valve stems. I believe they are the Comp Cams #780-16 retainers.
COMP Cams 780-16 COMP Cams Steel Valve Spring Retainers | Summit Racing
I’d like to get $20.00 plus the shipping for the set.
Ken
Edison, NJ
The inside step interferes with the damper spring inside the OEM 340 springs so they won't work.
