wilky70
Member
Does anyone have good write up on how to remove and replace a power steering box in a 72 Duster (318 auto)
Thank you in advance
Do you have headers?Does anyone have good write up on how to remove and replace a power steering box in a 72 Duster (318 auto)
I have stock manifoldsDo you have headers?
Okay, thank youGoogle it, there will be a youtube video. Its pretty easy just a few bolts to the k frame and a in in the steering shaft sleeve that locks the shaft to the box
Sorry I missed the earlier post, yes I will.Will I need to unbolt the steering column from inside the car?
BTW....To slide the column back, you'll need to remove the 2 bolts (not the 3 bolt flange) at the firewall flange were the column goes through.Sorry I missed the earlier post, yes I will.
Haha in fairness i had motor outIf you have headers the front lower control arm has to be removed. Move the torsion bar back. Remove rotors. The calipers have to be put out of the way. Steering knuckle and back plate come off. Just did one on a 73 Dart 340 H code with a stick.
lol I had the motor in. Had to remove the LCA along with the tie rod center link Pittman arm. I just removed the entire front end and replaced every bushing call joints pivots. HEADERS made the steering box removal a pain in the ***Haha in fairness i had motor out
