Steering column question
zigs
Yakima, Washington
I picked up a 66 Belvedere manual floor shift steering column. It has no lower bearing. The rubber seal is there. I was told that it didn't need the lower bearing because the shaft was stabilized by the steering joint. Anyone know if this is true , I'm going to rebuild the column. I can't find any info on it.
