Steering effort for manual 16:1 - should it be this high?
Suspension, Steering and Chassis
  1. 66fs
    66fs FABO Gold Member FABO Gold Member
    6,334
    2850
    Sep 9, 2009
    Greenwood, South Carolina
    Local Time:
    10:45 PM
    Might just need the manual box pitman arm with the smaller spline shaft.
    • Agree Agree x 1
    • DionR
      DionR Well-Known Member
      2,769
      682
      May 7, 2008
      Spokane, WA
      Local Time:
      7:45 PM
      • Thanks! Thanks! x 1
      • mvh
        mvh FABO Gold Member FABO Gold Member
        1,767
        470
        Dec 17, 2007
        Menlo Park, CA
        Local Time:
        7:45 PM
        I just want to point out that the small diameter steering wheel is the easiest thing to change, and will have a large effect on perceived effort.
        The whole point of a small steering wheel is that it enables quick turning WHEN YOU HAVE LIGHT STEERING EFFORT (as in a go-kart or small sports car). But the entire rest of your set-up is creating HIGH steering effort. So something has to give. If you are really in love with that wheel, I think you will have to go to power steering. The Borgeson quick ratio system is very nice — I have it in my convertible. My fastback has a factory manual box (24:1) and a stock steering wheel with 215/70-14 tires, and I find that makes for very heavy steering getting out of parking places, plus it is too slow to keep up with hairpin switchbacks on the road, which the Borgeson handles easily.
        • Like Like x 1
        • cookietruck
          cookietruck Well-Known Member
          1,099
          280
          Jun 25, 2012
          alkdfnoi
          Local Time:
          9:45 PM
          I put a 16:1 PST manual box on my 67 b-body. I had to pull it right back off because it had some slop in the sector shaft. I will say though, I was surprised how easy it was to turn the wheels in the garage standing still. Much easier than a PS box without the engine running. I could do a 1/4 turn on the wheel with one hand, factory steering wheel. 225/70 tires on the front and the air pressure is a little low.
          Now...I need to put the replacement box on the car and it is a little tighter than the first box I had on the car, but I don't see that making a huge difference.
        • RustyRatRod
          RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
          81,511
          61120
          Jun 7, 2010
          Georgia
          Local Time:
          10:45 PM
          It helps with good steering return as well, which is also a good benefit to have racing. That's what causes the wheel to want to return to center. Positive caster. But, a lot of serious road racing vehicles do run very low and even negative caster. It all depends on what you're doing.
        • Swinger 340
          Swinger 340 Well-Known Member
          98
          65
          Jun 9, 2021
          Lake Placid, Florida
          Local Time:
          10:45 PM
          Lots of good information here, I would like to add. The tire size here seems to be the largest downfall in this app. I have a 72' Dodge B-300 van that I installed TA G60's on a 15" US-Indy rim(special ordered). About every 3 years I need to have the frame at the gearbox welded, due to cracks. Never had that problem with the stock tires. The wider tire takes much more effort to move then the thinner ones. I like my profile of the van, so this is what I have to live with. Enjoy!!!!
        • kursplat
          kursplat FABO Gold Member FABO Gold Member
          4,306
          3273
          Aug 24, 2010
          so cal
          Local Time:
          7:45 PM
          talk to @BergmanAutoCraft he has complete setups or can piece together what you want
          • pishta
            pishta I know I'm right....
            21,804
            11236
            Oct 13, 2004
            Tustin, CA
            Local Time:
            7:45 PM
            • kursplat
              4,306
              3273
              Aug 24, 2010
              so cal
              Local Time:
              7:45 PM
            • pishta
              21,804
              11236
              Oct 13, 2004
              Tustin, CA
              Local Time:
              7:45 PM
              you can adapt about anything.....Is that Borgeson power box a bolt in? thats tiny!
            • kursplat
              4,306
              3273
              Aug 24, 2010
              so cal
              Local Time:
              7:45 PM
              yup, just got this working
              • Like Like x 1
              • Jeremiah
                Jeremiah Well-Known Member
                232
                220
                Oct 2, 2013
                Rogue River, OR
                Local Time:
                7:45 PM
                My 383 4-speed '68 GTS has a 16:1 box with fast ratio arms. G70-14 polyglass on the front. It has the original steering wheel and 100% stock front end, iron heads and exhaust manifolds. It's heavy and quite fun. Definitelt takes some muscle and finess in a stick car. That steering wheel is killing your good time IMO. Look at quarter max or speedway for a bigger wheel in that style.
                • Like Like x 1
                • MRGTX
                  MRGTX Well-Known Member
                  1,981
                  777
                  Sep 24, 2007
                  CT, USA
                  Local Time:
                  9:45 PM
                  how do you like it? I have no idea what kind of current something like this might draw. Did you need to upgrade the alternator or anything else?
                • MRGTX
                  1,981
                  777
                  Sep 24, 2007
                  CT, USA
                  Local Time:
                  9:45 PM
                  Good point about the stick shift. Those moments when you only have one hand on the wheel could be problematic at times.
                • kursplat
                  4,306
                  3273
                  Aug 24, 2010
                  so cal
                  Local Time:
                  7:45 PM
                  only done one test drive so far but it's just right. full assist is firmer than a stock 60's P/S setup, not over boosted, but still 1 armed parking lot doable. with the assist at it's lowest it's almost as if it's off. i used a kit from EPAS Performance. it's a very nice set up and if i'd used the stock column, and just followed their instructions, it would have gone easy. since i had an IDIDIT tilt column i wanted to use, i managed to over complicate it, much to my enjoyment :D. also the floor plate for their kit is only for a 65'. they didn't realize all the different A-body floor plates that were used. i've sent them the info to correct that. i just made my own from 3/8" aluminum. as far as the alternator, i already have a 75A powermaster with a lot of re-wiring. supposedly this only draws 9A max
                  edit: 15" steering wheel
                  • Like Like x 1
                  • MRGTX
                    1,981
                    777
                    Sep 24, 2007
                    CT, USA
                    Local Time:
                    9:45 PM
                    Sounds like a great option. Thanks for the info on this. It looks like these systems are over a grand new. I’ll keep an eye out for a used one as a possibility…
                    Also, well done on helping them out with the technical info.
                  • sccachallenger
                    sccachallenger Well-Known Member
                    345
                    153
                    May 18, 2015
                    north carolina
                    Local Time:
                    10:45 PM
                    LOTS of great information in this thread!
                    So what tire size on the front, what rim width, what back spacing?
                  • kursplat
                    4,306
                    3273
                    Aug 24, 2010
                    so cal
                    Local Time:
                    7:45 PM
                    there are threads on reusing toyota setups and others.
                    example: Electric power steering
