Steering pump
Discussion in 'Suspension, Steering and Chassis' started by COUDA, Jun 11, 2018.
  1. COUDA
    COUDA Well-Known Member
    93
    22
    Oct 10, 2017
    FRANCE
    Local Time:
    6:11 PM
    I changed my steering box for a Borgeson. Problem: The oil is boiling and there is a noise all the time. Do you know what is the problem?
  2. Frnknsteen
    Frnknsteen FABO Gold Member FABO Gold Member
    490
    264
    May 26, 2011
    Spencer, IN
    Local Time:
    12:11 PM
    Is the fluid boiling,.... or foaming. My guess is that it is foaming. Check for a leak on the return line from the steering gear, you may be pulling in air, causing it to look foamy. Keep in mind that line is not under pressure so it may not have a visible leak while running, where fluid is coming out, rather it may be pulling in air. Could leak when shut off though.
    The noise you are hearing could be cavitation in the pump. If that's the case, you want to get it fixed soon. Cavitation can cause major issues inside the pump.
    • Agree Agree x 2
    • Like Like x 1
    • AJ/FormS
      AJ/FormS 367 FormS clone 3.09-1.92-1.40-1.09-.78od 3.55s
      14,867
      4029
      Jan 19, 2014
      South-Central Manitoba,Canada, 900ftelevation
      View My Photos
      Local Time:
      11:11 AM
      With the factory system, assist is only supplied under command of the control-valve. But that control-valve is now history.
      How does the new unit handle this? If the pump is asked to make full pressure all the time, then yes it will boil the oil. You will probably need a cooler; something that presents a very low resistance to the continuously circulating oil.
    • COUDA
      93
      22
      Oct 10, 2017
      FRANCE
      Local Time:
      6:11 PM
      I understood the problem.Borgeson steering box have the assembly of inverted hoses.
      I had not seen it.Low pressure: left and: high pressure right.
      • Like Like x 3
      • COUDA
        93
        22
        Oct 10, 2017
        FRANCE
        Local Time:
        6:11 PM
        Not a lot of explanation at Borgeson.Too bad.
        • Agree Agree x 1
        • COUDA
          93
          22
          Oct 10, 2017
          FRANCE
          Local Time:
          6:11 PM
          I still have the problem. I start the engine and after 5 minutes, the oil is boiling and the steering pump overflow.
        • COUDA
          93
          22
          Oct 10, 2017
          FRANCE
          Local Time:
          6:11 PM
          I contacted Borgeson and they anserwed:"We do not recommend you use ATF. We recommend using a non-synthetic power steering fluid."So ,do you know what oil?
        • Dusterfreak
          Dusterfreak Well-Known Member
          114
          10
          Aug 29, 2010
          Finland
          View My Photos
          Local Time:
          6:11 PM
          Hi Couda, did you found out whats wrong?? I have a similar problem, after 5 miles or so the pump starts to squeel, its cavitatin and cant find a reason.
