Steering wheel moves on its own
Discussion in 'Suspension, Steering and Chassis' started by Big Green Duster, May 15, 2018.
  1. Big Green Duster
    Big Green Duster Well-Known Member
    83
    63
    May 20, 2017
    19020
    Local Time:
    1:59 PM
    I recently installed a new power steering pump on my car and now when ever I start the car the steering wheel turns all the way to the left. Can some one tell me what I messed up on or is the pump at fault?
  2. brian6pac
    brian6pac Well-Known Member
    3,009
    1506
    Nov 15, 2016
    N.E.Ohio
    Local Time:
    1:59 PM
    the valve on top of the box is off center, did you remove the 2 bolts in the top cover were the return line goes?
    • Like Like x 1
    • Agree Agree x 1
    • Big Green Duster
      83
      63
      May 20, 2017
      19020
      Local Time:
      1:59 PM
      Yes i did remove the valve
    • Big Green Duster
      83
      63
      May 20, 2017
      19020
      Local Time:
      1:59 PM
      Ill make sure to center it when this storm passes. Thanks
    • brian6pac
      3,009
      1506
      Nov 15, 2016
      N.E.Ohio
      Local Time:
      1:59 PM
      now you have to adjust it, Do you know how to do it?
    • Big Green Duster
      83
      63
      May 20, 2017
      19020
      Local Time:
      1:59 PM
      No
    • brian6pac
      3,009
      1506
      Nov 15, 2016
      N.E.Ohio
      Local Time:
      1:59 PM
      Jack it up so both front wheels are in the air, then crack the bolts loose on the valve. This is very importent DO NOT REACH THROUGH THE STEERING WHEEL TO START if you do when it starts it will try to break your arm when the wheel turns. now with it running take a small hammer and tap the valve to the rear and then to the front till you find the happy spot, tighten the bolts and shut it off. Start it up and see if the wheel kicks right or left make a fine adjustment till it starts without kicking and you will be good. good luck!
      • Thanks! Thanks! x 2
      • Agree Agree x 1
      • Big Green Duster
        83
        63
        May 20, 2017
        19020
        Local Time:
        1:59 PM
        Thank you, really appreciate it.
