Originalowner73 340duster
I have over flow tank that won't work in my car..I'm going to temporarily put it in and see what it does after fully warmed upAs Tooljunky pointed out if you run without an overflow (or for that matter a cap on) the level in the rad would need to be lower because as the coolant heats up it expands and will flow out. most cars with overflow bottle can have a 2-4 inch rise in the fluid level in the overflow bottle between cold and hot.
I'm starting to think there is nothing wrong. Fill it up, put the cap on, let it run till the temp gauge shows normal, let it cool and recheck the fluid levels. Listen for boiling after it is shut off to cool.
