circlepilot
Stock 225 solid lifter cam, valves and springs. They came out of the 65 Barracuda Super 225 that I have since made extensive changes to. The engine had, as best I could tell, 48,000 miles on it since new, but had been overhauled, by the PO, .030 over on the crank and bore. The engine was running great. Fuel pump lobe and oil pump / dist. gear look fine. Bead blasted the valve tulips and face. They appear to be very serviceable.
50.00 plus shipping from 71730
