I recently purchased a 48 plymouth into which someone swapped a small block mopar engine. After looking up the casting numbers what I thought was probably a 318 is actually a 273 with a late (december I think) 1964 casting date. I'm assuming the engine started it's life in an a-body based on that. It appears stock with the 2 barrel carb but it is connected to a later 904 tranny (not pushbutton).
I recently lucked into an Edelbrock D64 intake (which is correct for my early heads) and while I'm sure dual quads are too much for the little 273 with the low compression pistons I'd like to run it anyway. Has anyone else had success with this combination and what did you run for carbs? Ideally I'd like to find something inexpensive to run for carbs but I also realize that you get what you pay for sometimes. Did you run progressive linkage on the carbs? I haven't been inside the engine but I would guess it's still running the stock camshaft. Any advice would be appreciated. Thanks.
