Stock 318 2 Barrel Cam Choice
Small Block Mopar Engine
  1. Killer6
    Killer6 Well-Known Member
    2,814
    985
    Mar 9, 2015
    PA
    Local Time:
    1:32 AM
    Ok, I stand corrected, so they have lopey-er idles for the duration. Guess they seemed too "market gimickey" oriented to Me, & I haven't paid much attention to them.
  2. RustyRatRod
    RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
    78,160
    55768
    Jun 7, 2010
    Georgia
    Local Time:
    2:32 AM
    They are.....but they also WORK. There have been many people use them in actual racing circles that have had great success. Could they have chosen something that would have worked "better"? Maybe, but they are a quick go to for that cool sound, plus if the rest of the build suits them they will work!
  3. Killer6
    2,814
    985
    Mar 9, 2015
    PA
    Local Time:
    1:32 AM
    Here's the upshot, if You don't want to pull the heads to have the guides shortened(I know...there ARE other workaround methods possible but), stay .475" max design lift. Wide LSA's improve driveability/idle which are more effective on higher durations. As already posted by others, keep the @.050 around 220deg max on the intake. The older cam I referenced had a smooth...read not aggressive.... profile, this makes it easier for the valve springs to control the valves, which are relatively light in a teener. Mine would start to "give in" just past 5,800rpm, so that's where I'd bang a gear. That 318 was out of a '74 Dart, I believe it had 78K(?) on it. Extreme Energy Hydraulics are great cams, but You will need to get the rec'd springs for sure.
    • Thanks! Thanks! x 1
    • Killer6
      2,814
      985
      Mar 9, 2015
      PA
      Local Time:
      1:32 AM
      My short impression'd be that it functions like a bigger cam scavenge-wise, and like a smaller one with an advanced IVC. Which I love tighter LSA's on a lot of the flow-starved stuff I've dealt with. I wasn't puttin' 'em down Dude, just sayin' why I haven't given them much attn.
    • eekvonzipper
      eekvonzipper My Member is Legendary! FABO Gold Member
      698
      559
      Apr 18, 2020
      Cadet, Missouri
      Local Time:
      1:32 AM
      So, Is there a Short Answer?
      I'm trying to use this to Decide on a Cam for My 273 2bbl 4-Speed Build.
      I'm doing a Freshen-Up this Winter for a Burning-Oil/Smoking Motor and I may just leave the old cam in there if it looks okay...
      • Like Like x 1
      • RustyRatRod
        78,160
        55768
        Jun 7, 2010
        Georgia
        Local Time:
        2:32 AM
        I know, I was just lettin you know they ain't the POS some would have you think.
        • Agree Agree x 1
        • Slantsix64
          Slantsix64 Well-Known Member
          3,160
          1325
          May 11, 2014
          SGV
          Local Time:
          1:32 AM
          i would swap some 3.55s keep the camshaft in the 260-264 duration .470 lift. Get a double roller timing chain with adjustable key ways and advance it 4 degrees that way you can build up some pressure giving you some low end.
          • Like Like x 1
          • Killer6
            2,814
            985
            Mar 9, 2015
            PA
            Local Time:
            1:32 AM
            Lol, OK. Like the Lunati Voodoo series....I just have an adverse reaction to that for some reason, they may be fine cams, but it's science & R&D not voodoo lol! I'm kinda like...just show Me the specs and a dyno curve & go back to making cams, lol....
          • RustyRatRod
            78,160
            55768
            Jun 7, 2010
            Georgia
            Local Time:
            2:32 AM
            They are good. Companies just feel like something has to have a snappy name or it won't sell. They figure their customers are stupid enough to fall for a snappy name. Some are, unfortunately.....but not everything with a snappy name is bad. A lot of things without the snappy name are good, though.
          • shittyslant6
            shittyslant6 Well-Known Member
            979
            1093
            Jan 25, 2021
            California
            Local Time:
            11:32 PM
            • Like Like x 1
            • toolmanmike
              toolmanmike Moderator Staff Member FABO Gold Member
              61,510
              50125
              Jan 18, 2006
              Iowa
              Local Time:
              1:32 AM
            • shittyslant6
              979
              1093
              Jan 25, 2021
              California
              Local Time:
              11:32 PM
              but @.50 it's .211
              (forgot to mention that when I wrote it)
              • Like Like x 1
              • toolmanmike
                61,510
                50125
                Jan 18, 2006
                Iowa
                Local Time:
                1:32 AM
              • shittyslant6
                979
                1093
                Jan 25, 2021
                California
                Local Time:
                11:32 PM
              • eekvonzipper
                698
                559
                Apr 18, 2020
                Cadet, Missouri
                Local Time:
                1:32 AM
              • shittyslant6
                979
                1093
                Jan 25, 2021
                California
                Local Time:
                11:32 PM
              • eekvonzipper
                698
                559
                Apr 18, 2020
                Cadet, Missouri
                Local Time:
                1:32 AM
                Ahh, Srry!
                • Like Like x 1
                • toolmanmike
                  61,510
                  50125
                  Jan 18, 2006
                  Iowa
                  Local Time:
                  1:32 AM
                  yep
                • shittyslant6
                  979
                  1093
                  Jan 25, 2021
                  California
                  Local Time:
                  11:32 PM
                  usually how it goes... extra $85 dollar mopar tax:rofl:
                  • Agree Agree x 1
                  • toolmanmike
                    61,510
                    50125
                    Jan 18, 2006
                    Iowa
                    Local Time:
                    1:32 AM
                  • shittyslant6
                    979
                    1093
                    Jan 25, 2021
                    California
                    Local Time:
                    11:32 PM
                    • Like Like x 1
                    • toolmanmike
                      61,510
                      50125
                      Jan 18, 2006
                      Iowa
                      Local Time:
                      1:32 AM
                      Yes it does. I don't find that cam for sale on Summit's site. Apparently a old Comp grind. @RustyRatRod mentioned in a post from a ways back "if you can find one". Maybe you better call Jegs.
                    • shittyslant6
                      979
                      1093
                      Jan 25, 2021
                      California
                      Local Time:
                      11:32 PM
                      alright, I will give them a call, I wouldn't be suprised if they didn't have it.
                      • Agree Agree x 1
                      • toolmanmike
                        61,510
                        50125
                        Jan 18, 2006
                        Iowa
                        Local Time:
                        1:32 AM
                        Might be old stock. Too bad it's a kit. You want the cam. I would use my own timing set and different lifters.
                      • shittyslant6
                        979
                        1093
                        Jan 25, 2021
                        California
                        Local Time:
                        11:32 PM
                        well they have just the cam, but I wanted the kit because this is the first time i'm doing this and I wanted to insure that all the parts are simpatico.
