Timmy's Toy
I have a 68 Dart bracket racer with a 360 in it. Car weighs in at 3,000lbs with my tubby body in it. Tranny is a 727 torqueflite with a 4500 stall converter, 8-3/4 rear with 4.57 gears. I shift at 6500 and run through the traps at 6800. Engine is a Mopar Performance short block with small chamber W2 heads, Indy Intake, and Hedman 1 7/8 race headers. I swapped the hydraulic 509 cam for a solid 557/296 Mopar Performance camshaft. Best run is 11.10 at 120mph. This engine has run for 4 years without a hitch. (knock on wood) It still runs strong but its time to tear her down and check out the vitals. Especially since the pistons are hypereutectic and the crank is cast. I would like to upgrade the reciprocating parts to a 408 stroker (all forged parts). I intend to deck the block and use flat top pistons that with the 55cc chamber heads should produce 12.0+ compression. Im going to have the heads ported completely and the intake matched, etc. With an aggressive .600+ inch camshaft this engine should produce lots of power. My question is: how much power can the stock 360 block take? Will the stock 2 bolt main block handle it? What concerns do you think I would have? Ive gotten a lots of conflicting advice on this and would like to hear thoughts from A engine racers.
Tim
Tim
