Slantsix64
So I got a mild 5.9 with ported heads .480 lift 224 duration@50 camshaft Holley 750cfm vacuum secondary long headers 2800 stall 3.91 gears out back.
I’m upgrading the line to 3/8 from 5/16 that’s around 40% more volume.
My question is would the pump need to be upgraded as well, I do have a Carter performance pump, just debating if volume is more important than pressure.
