So I know that there are those that say a stock capacity oil pan and a HV oil pump can pump the pan dry when high rpms are used. But I was also told that this could never happen, so I dont know what to believe. Originally I had a moroso deep pan, and it was stupid to run on the street, it scraped on everything! not fun at all. Good oil capacity though.
I have a stock 360 pan, and am using the same HV oil pump this time. The car is really only a street car, probably 6K RPMs max and only occasionally for short periods. I am wanting to use this pan, I know milodon and kevko make other kicked out pans, but I already have this pan. I also am going to use a windage tray this time for better oil control.
Would I be able to run this combination? and would the windage tray help? Main issue here is ground clearance and budget, pan is a few hundred bucks that I could use somewhere else.
