stock or hv oil pump
Small Block Mopar Engine
  1. pittsburghracer
    pittsburghracer FABO Gold Member FABO Gold Member
    3,234
    5807
    Apr 20, 2016
    Freeport, PA.
    Local Time:
    11:37 AM
    132D696D-C8E9-486E-B508-85653C14C851.jpeg A09722C5-7929-4531-9A25-A0068079A010.jpeg E6B7BB7A-203E-4B35-9C3C-6E3368D4B628.jpeg
    No I haven’t but we had a lifter bar break on a set of 828-16 lifters in my sons 360 that ran 6.54 trashing the whole engine. About 50 runs on those lifters. This weeks project. Bam lifters fit with zero grinding
    • Like Like x 2
    • pittsburghracer
      3,234
      5807
      Apr 20, 2016
      Freeport, PA.
      Local Time:
      11:37 AM
      89505EFB-5843-493F-9E8A-488D4671ABEC.jpeg 3A29D982-599C-4D42-B248-572BC09FBC41.jpeg It’s out on my scrap pile now and very hard to see the hours I had in this one to get Comp lifters in it. Block is also tubed.
      • Like Like x 1
      • 12swinger
        12swinger Well-Known Member
        416
        505
        Jun 26, 2013
        Hoosier
        Local Time:
        10:37 AM
        I have that same lifter and about to fire the engine in the next week or so.
        Your making me nervous.
      • 12swinger
        416
        505
        Jun 26, 2013
        Hoosier
        Local Time:
        10:37 AM
        I have a crap load of hours making that lifter work also.
        • Agree Agree x 1
        • MerlinsMopar
          MerlinsMopar FABO Gold Member FABO Gold Member
          228
          237
          Jun 6, 2014
          Middletown Pa
          Local Time:
          11:37 AM
          MV-72HV every build and dont forget the mopar black spring. Always 60-80 psi depending on rpms. They need atleast 10 psi over rpms. 70psi for 6k. If you tach 6000 and only have 50 psi, you are burning up your bearings.
        • MOPAROFFICIAL
          MOPAROFFICIAL Well-Known Member
          5,441
          4420
          Jun 1, 2016
          Beach
          Local Time:
          8:37 AM
          • Like Like x 2
          • Thanks! Thanks! x 1
          • MOPAROFFICIAL
            5,441
            4420
            Jun 1, 2016
            Beach
            Local Time:
            8:37 AM
            Bummer.
            I hate comp cams anything.
            Morell lifters for me.
            • Agree Agree x 1
            • Idaho
              Idaho FABO Gold Member FABO Gold Member
              2,579
              244
              Oct 17, 2006
              Local Time:
              8:37 AM
              Since windage is part of the discussion I'll throw this in. I was a tad shocked at the 42 HP assertion. Still wondering if it could be a typo (or a paid ad by Moroso). If real, every stroker should get a deep pan. I don't know if the Magnum truck pan would qualify. I'm guessing not. At least its a rear sump. I would think a windage tray of some sort is also in order.
            • fishmens67
              fishmens67 Well-Known Member
              7,320
              4568
              Nov 10, 2012
              idaho
              Local Time:
              10:37 AM
              seen the effects of standard pump/ high pressure vs HV pumps a few times in different engines with varying clearances.
              I will stick with a standard pump with high pressure spring on my street car. 45 psi at hot idle and 70 psi at 2000 rpm and up.
              • Like Like x 1
              • Idaho
                2,579
                244
                Oct 17, 2006
                Local Time:
                8:37 AM
                I just ground some casting flash. I had two thoughts. Mainly, some looked as if it could break loose and cause trouble. Then, the machinist will see I'm paying attention.
                I did also find a small casting defect right in a corner of the oil pan rail that could predispose to a crack. It was ground smooth.
                Szilagyi talks about a hole to oil the fuel pump eccentric but no mention of chain oiling.
                Of course no fuel pump on the Magnum but does it have the same chain oiling issue?
              • MOPAROFFICIAL
                5,441
                4420
                Jun 1, 2016
                Beach
                Local Time:
                8:37 AM
                Stock m72 does that on its own.
                Yee haw
                • Agree Agree x 1
                • MOPAROFFICIAL
                  5,441
                  4420
                  Jun 1, 2016
                  Beach
                  Local Time:
                  8:37 AM
                  R you thinking what im thinking?
                  God help us.
                • 4spdragtop
                  4spdragtop FABO Gold Member FABO Gold Member
                  28,905
                  8843
                  Aug 28, 2009
                  Wasting time here
                  Local Time:
                  10:37 AM
                  The M72 std vol has a 70-75 psi bypass spring in it.
                  • Agree Agree x 1
                  • mario03srt
                    mario03srt FABO Gold Member FABO Gold Member
                    549
                    125
                    Apr 12, 2015
                    Amelia Oh
                    Local Time:
                    11:37 AM
                    The stock Chrysler 360 car oil pan (4 qt?) is a joke for a high performance motor. This is the pan I chose with the Milodon p/u and a 72HV pump. Should I stroke/boost this baby I'm ready for the added demands. But even as, is the stock pan/pump has got to be cavitating or running on the edge during launches, long pulls, hard turns. The P/U and the pump work great together, not sure about in a stock setup, but who is to argue with MOPAR and their testing, I don't think that they would fabricate results.
                  • 12swinger
                    416
                    505
                    Jun 26, 2013
                    Hoosier
                    Local Time:
                    10:37 AM
                    I ran that pan and pickup in my Dart, before going to the super stock oil pan.
                    I moved away from a Hamburger pan, as I figured the oil would be moved out and away from the crank with that pan, and it was a little less deep.
                    What I didn’t foresee was the headers hit the damn pan something fierce had to beat the sucker up, I wasn’t modifying my headers as they were Hooker super comps.
                  • mario03srt
                    549
                    125
                    Apr 12, 2015
                    Amelia Oh
                    Local Time:
                    11:37 AM
                    Rusty/All,
                    The limiting dimension on the oil pump inlet and flow performance is the "inner" diameter of the feed tube. Not the Hole in the pump. The outer diameter of the tube is restricted by the pump housing inlet hole. Now there is a limit obviously as to how thin to make the feed tube without it fracturing due to load or harmonics etc to accept a Melling Pump female inlet ID.
                    "In general, the flow rate increases proportional to the square of the inside diameter, hence the flow rate is directly proportional to the area of pipe cross-section. The larger the diameter, the greater flow." I'm sure we agree on this.
                    I found a calculator online and used .375 and .425 tube diameters as examples flowing 10 feet per second. The .375 diameter flowed 3.44 gallons per minute (GPM) and the .425 flowed 4.42 gpm. That's a one gallon increase in a minute by increasing the oil pickup tube "inner" diameter by only .050 thousands. BTW these again are made up parameters I do not know the actual dimensions.
                    FLOW RATE CALCULATOR
                    FYI,
                    Marion
                    • Like Like x 4
                    • yellow rose
                      yellow rose Doctor of Thinkology.
                      21,112
                      17168
                      Jun 19, 2015
                      Living on the razors edge
                      Local Time:
                      8:37 AM
                      I can't get that calculator to work.
                      Can you do the calculations for a 15/16 inner diameter tube? I also think you need to slow the velocity down a bit. 10 feet a second sounds awful fast to me.
                      TIA
                      YR
                    • pittsburghracer
                      3,234
                      5807
                      Apr 20, 2016
                      Freeport, PA.
                      Local Time:
                      11:37 AM
                      8CAE81DE-260D-41B1-8CAC-686EF436FFD7.jpeg E52E7F1B-517B-4B29-B2FA-4DF3E9BC619A.jpeg You could always get fancy like one of our members did on a block and parts I bought from him a few years ago. I forget what he goes by on here but I got him to sign up.
                      • Like Like x 1
                      • QuickDart360
                        QuickDart360 Well-Known Member
                        1,112
                        392
                        Apr 5, 2014
                        San Antonio
                        Local Time:
                        10:37 AM
                        Had a friend that owns a 1969 pontiac grand prix with a hot rodded 400 pontiac motor. He went thru 2 junk comp cams! And he's a professional mechanic! So he was doing cam break in as recommended. He got fed up and went to a crane grind. All was well!!
                        • Like Like x 1
                        • yellow rose
                          21,112
                          17168
                          Jun 19, 2015
                          Local Time:
                          8:37 AM
                          That system right there will feed enough oil to easily oil the crank to 10k plus.
                          • Like Like x 1
                          • Jadaharabi
                            Jadaharabi FABO Gold Member FABO Gold Member
                            7,101
                            7594
                            Jan 8, 2016
                            Peoria, Illinois
                            Local Time:
                            10:37 AM
                            Has anybody ever drilled or cut a hole in the webbing of the mains so that there is air flow between the mains?
                          • pittsburghracer
                            3,234
                            5807
                            Apr 20, 2016
                            Freeport, PA.
                            Local Time:
                            11:37 AM
                            I think some guys are over thinking this. An LA small block will take a lot of horsepower with almost zero work. I don’t think you really want to go drilling holes in what is probably the weakest part of the block. Not trying to be a smart ass but hot air doesn’t cool very well.
                            • Agree Agree x 2
                            • Like Like x 1
                            • Jadaharabi
                              7,101
                              7594
                              Jan 8, 2016
                              Peoria, Illinois
                              Local Time:
                              10:37 AM
                              My understanding is that the holes equalize or balances the pressure produced by the up and down movement of the pistons.
                              Never tried it just something I heard.
                              • Like Like x 1
                              • QuickDart360
                                1,112
                                392
                                Apr 5, 2014
                                San Antonio
                                Local Time:
                                10:37 AM
                                My dad worked for a chrysler/dodge dealer from 1963-1979. He worked on 340 6 packs hemis 340 demons, etc. He never saw any have issues with oiling. All were stock and run hard especially the 340's. He did have some come in that blew a rod but he says it was overreved or just plain abuse!
                                • Agree Agree x 1
                                • Max1196
                                  Max1196 Well-Known Member
                                  816
                                  546
                                  May 12, 2016
                                  Swift Current SK
                                  Local Time:
                                  9:37 AM
                                  You mean like how the factory did it on this 65' 318? 5 out of 6 webs have holes.
