Straightening particle board panels
Mopar Interiors
  1. jcmeyer5
    jcmeyer5 Well-Known Member
    93
    101
    Jan 7, 2019
    Indiana
    Local Time:
    9:31 PM
    I have all 4 interior panels out of the car now. I am working on getting them rehabilitated for use. I regulars the front edge of the rear driver panel (pics attached). The front panel is warped. I’d like to unwarp it. Any ideas how?
    • Like Like x 1
    • 1969383S
      1969383S FABO Gold Member FABO Gold Member
      4,780
      1945
      Jan 8, 2012
      Cumming, GA.
      Local Time:
      9:31 PM
      Pressure and A little steam at the same time! Pressure to last longer!
      • Thanks! Thanks! x 1
      • Agree Agree x 1
      • circlepilot
        circlepilot FABO Gold Member FABO Gold Member
        537
        308
        Nov 15, 2014
        El Dorado, Arkansas
        Local Time:
        8:31 PM
        This is just a suggestion. I'm sure that there will be some others. I have had good luck taking the warp out of wood sheet this way. Mix some ammonia and water (1 part ammonia / two parts of water) into a spray bottle. Spray (you can use a sponge also) as much of the warped area until the panel shows that it soaking up the solution. Lay the panel on a flat surface wet side down (preferably on hot concrete walkway or patio) and put a sheet of wood, thicker than the panel on the panel and add weights to completely hold it down. Let it dry that way completely, maybe a day or two. It should take set.
        Norm
        • Like Like x 2
        • Agree Agree x 1
        • jcmeyer5
          93
          101
          Jan 7, 2019
          Indiana
          Local Time:
          9:31 PM
          Thanks guys.
        • moparmandan
          moparmandan FABO Gold Member FABO Gold Member
          1,851
          1625
          Jun 28, 2017
          Central FL
          Local Time:
          9:31 PM
          Pretty much what I did. I used straight water and 2 pieces of plywood. Got my door card good and wet, then sandwiched it between the pieces of plywood on concrete with bricks for weight. Worked fine.
        • jcmeyer5
          93
          101
          Jan 7, 2019
          Indiana
          Local Time:
          9:31 PM
          See, it didn’t work for me. I tried soaking it, pressing it flat, but it still was warped. I went to using a lot he’s iron on the wet particle board. That worked well. It’s not perfectly flat, but it’s good enough.
          • Like Like x 1
          • RustyRatRod
            RustyRatRod 30 Degrees Outta Whack
            55,632
            24271
            Jun 7, 2010
            Georgia
            Local Time:
            9:31 PM
            I wouldn't even mess with it. Use it for a template and get some 1/4" marine grade plywood and make some more. But remember wherever you drill holes in it, you need to reseal it with polyurethane so moisture won't get in. Then they will outlast you.
          • 66Dvert
            66Dvert Working on my custom car parts again! FABO Gold Member
            2,284
            534
            Nov 2, 2008
            Webster , florida
            Local Time:
            9:31 PM
            I use 1/8" ABS to make door panels and seat back pieces Lincoln 60's to 70's and Porche door pockets, nice money maker for me!)for my boss for his interior business. I'll be making duplicates of the backer board for the dart,plymouth door panels (number 6 on the list) But my darned glove box project is holding me up.
            seat back for a 64 Lincoln Since they are ABS these panels won't degrade at all if not left out in sunlight(or even in sunlight for many years)
            cutting the door panels
            and last but not least is the ABS door panels for his lincoln
            • Like Like x 1
            • jcmeyer5
              93
              101
              Jan 7, 2019
              Indiana
              Local Time:
              9:31 PM
              Nice. Do you use the stock upholstery on them?
            • 66Dvert
              2,284
              534
              Nov 2, 2008
              Webster , florida
              Local Time:
              9:31 PM
              Ostritch and Alligator on this one though
              yeah, usually it is just stock interiors that we put back on the panels. Just peel the old ones off carefully and spray contact cement on the new ones, add new carpet and bindings as roll the bindings over to finish. here is one we had to do to send to India(no leather was involved and it matched the love of color people that live there love)
              that a big bulky armrest that is padded on the door panel. pain in the behind to do,
              her I am installing the insert to the top panel and getting it ready to ship out along with the other 3 I just finished..total pain in the behind to do but worth it on the finished car (well he liked it, not me!)
