1. pishta
    pishta I know I'm right....
    21,388
    10777
    Oct 13, 2004
    Tustin, CA
    Local Time:
    3:32 AM
    check out the oil filter up top! Was this a pre-production press photo for the 64 Valiant V8?
    [​IMG]
  2. 66340SEDAN
    66340SEDAN FABO Member #3649 FABO Gold Member
    21,565
    14418
    Nov 20, 2006
    Minnesota
    Local Time:
    5:32 AM
    That is not the correct exhaust manifold for an a-body, alternator looks different as well. My guess is its a pic of an industrial engine or its a export engine.
  3. C130 Chief
    C130 Chief Mechanical Genius
    3,064
    253
    Nov 23, 2005
    Boise, ID
    Local Time:
    4:32 AM
    Right hand drive. Think Australia.
    • Like Like x 1
    • yellow rose
      yellow rose Overnight Sensation
      28,501
      25174
      Jun 19, 2015
      Central Washington
      Local Time:
      3:32 AM
      How can you tell it is RH drive?
    • 66340SEDAN
      21,565
      14418
      Nov 20, 2006
      Minnesota
      Local Time:
      5:32 AM
      If used on right hand drive, the oil filter would hit the steering shaft so it needs to be relocated.
    • Dartswinger70
      Dartswinger70 Only thing I ever bought new was a Fender Strat
      3,626
      2018
      Sep 20, 2005
      Southeastern Pa.
      Local Time:
      6:32 AM
      I have seen top loader oil filters on small block Chevys from early 60's That sure looks ike a MOPER
    • yellow rose
      28,501
      25174
      Jun 19, 2015
      Central Washington
      Local Time:
      3:32 AM
      Well dayum, never thought of that one.
      Makes sense.
    • 67Dart273
      67Dart273 FABO Gold Member FABO Gold Member
      51,498
      20462
      Oct 14, 2010
      Idaho
      Local Time:
      3:32 AM
      Also notice the alternator is not Mopar
    • jos51700
      jos51700 Green Bearing thread connoisseur
      5,956
      2731
      May 24, 2009
      Bel-Ray
      Local Time:
      5:32 AM
      You know it's overseas just because it says "litre".
    • pishta
      21,388
      10777
      Oct 13, 2004
      Tustin, CA
      Local Time:
      3:32 AM
      yup, forgot the early A snake manifold. Makes sense....export. Painted exhaust, oi!
    • 273
      273 Well-Known Member
      3,781
      1526
      May 14, 2012
      Ontario
      Local Time:
      6:32 AM
      And it's after 66 cause of the slip yoke on the tranny
    • nm9stheham
      nm9stheham Well-Known Member
      12,089
      3979
      Dec 20, 2013
      Waynesboro, VA
      Local Time:
      6:32 AM
      Actually, that 'oil filter' looks like a pre-pump fuel filter, and perhaps a water separator.... pretty common on engines used in rural overseas areas where the fuel supply is not nearly so clean as here. You can see what looks like a fuel line and 90* brass fitting on the rear underside of that assembly.
    • 66fs
      66fs FABO Gold Member FABO Gold Member
      6,149
      2661
      Sep 9, 2009
      Greenwood, South Carolina
      Local Time:
      6:32 AM
      I was also thinking Export. That sounds logical. I like the exhaust Y pipe also. Very interesting.
    • Hysteric
      Hysteric Well-Known Member
      572
      255
      Dec 31, 2005
      Local Time:
      5:32 AM
      Looks to be an Australian 273.
    • gold66cuda
      gold66cuda Well-Known Member
      224
      55
      Jan 1, 2012
      Victoria
      Local Time:
      3:32 AM
      I have seen this before somewhere, Australian right hand drive a per 66340SEDAN'S comments, motor mount 67 and up also.
    • RustyRatRod
      RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
      79,466
      57899
      Jun 7, 2010
      Georgia
      Local Time:
      6:32 AM
      It's a picture of a motor.
    • gold66cuda
      224
      55
      Jan 1, 2012
      Victoria
      Local Time:
      3:32 AM
      It's actually a photograph of an engine and automatic transmission. I think motors are electric. This looks like an internal combustion engine possibly made to be installed in an right hand drive Australian produced Chrysler powered vehicle post 1966.
    • RustyRatRod
      79,466
      57899
      Jun 7, 2010
      Georgia
      Local Time:
      6:32 AM
      From Webster:
      Full Definition of motor
      1
      : one that imparts motion; specifically : prime mover
      2
      : any of various power units that develop energy or impart motion: as
      a : a small compact engine
      b : internal combustion engine; especially : a gasoline engine
      c : a rotating machine that transforms electrical energy into mechanical energy
      3
      : motor vehicle; especially : automobile
      motordom play \-dəm\ noun
      I don't think Atlanta MOTOR Speedway has a damn thing to do with electric motors. I think GENERAL MOTORS makes WAY more internal combustion motors than electric motors.
    • peedee
      peedee Well-Known Member
      188
      99
      Aug 22, 2011
      Australia
      Local Time:
      12:32 AM
      Definitely Chrysler Australia offering from 1966 to early 1967 , would be an earl lucas or email alternator. then we went to 318 with oil filter mounted to intake manifold with metal pipes to normal oil filter location as our steering box is located on the right hand chassis rail right next to the oil filter plate
      [​IMG]
    • gold66cuda
      224
      55
      Jan 1, 2012
      Victoria
      Local Time:
      3:32 AM
      Thanks for passing along Websters definitions of a motor, it confirms the original posters picture with the word "engine" may if fact be correct.
      Not sure how they came up with the name Atlanta Motor Speedway or General Motors came up with their name but interestingly enough I was on General Motors website the other day and the only motors they sell move windows, seats, sunroofs and other things that require 12 volts to run, and they don't look anything like the picture the the original poster posted. They do sell lots of performance crate engines and replacement engines, engine parts diesel and gas powered however. Interesting as well as the Ford Motor Company site is very similar. I'm so confused!! Can you check into this for me, maybe Websters can help you out. I believe you may work in the automotive parts business so I really value your opinion.
    • nm9stheham
      12,089
      3979
      Dec 20, 2013
      Waynesboro, VA
      Local Time:
      6:32 AM
      Cool... I bet that oil filter makes one helluva mess when you pull it off.....LOL I like the "Fireball 318" name... makes me think of those end-of-the-world road warrior movies set in the outback...
    • diymirage
      diymirage HP@idle > hondaHP@redline
      26,234
      24424
      Oct 12, 2012
      michigan
      Local Time:
      6:32 AM
      yall had email in 67 ? :pale:
      I don't even think we had indoor plumbing back then
    • Ters
      Ters Mopar infected...
      251
      28
      Sep 19, 2015
      Pretoria, South Africa.
      Local Time:
      1:32 PM
      As is our South African /6 filters, mounted on the valve cover. And yes, it does make a mess when changing... Non original alternator courtesy of previous owner.#-o
      Ters.
    • toolmanmike
      toolmanmike Moderator Staff Member FABO Gold Member
      62,400
      51606
      Jan 18, 2006
      Iowa
      Local Time:
      5:32 AM
      We need to ask Steppenwolf. "Get your motor runnin' head out on the highway."
    • forphorty
      forphorty Well-Known Member
      785
      401
      Jan 19, 2006
      Local Time:
      5:32 AM
      Dang, Junior Johnson sure is gonna feel foolish when he finds out that he had it wrong all these years.
      http://hotrodenginetech.com/chevrolet-427-mystery-motor/
