Map63Vette
So I noticed the other day when I nailed it in first gear on an onramp that my oil pressure warning light came on. It's not the typical dummy light as I can program the pressure range I want it to light at vs rpm, so I know it wasn't totally dropping pressure, but I wasn't logging at the time to look at it more closely. I noticed it did it again the other day, so today I made a point of trying to replicate the issue while logging to see what was going on. When running normally my oil pressure tends to be somewhere around 50-60 psi, maybe down to 40-45 when things get hot and the rpms drop, but nothing that would have my worried. However, looking at the log, as my rpm was climbing, my oil pressure was dropping away. Based on the way it builds then drops, I'm thinking maybe I'm just low on oil, but since it keeps some amount of pressure and doesn't fall all the way to zero I'm not quite sure what to think.
On the plus side, my traction control works really nicely. That first drop in pressure happens to correspond with the traction control pulling timing, but after the gear shift there wasn't any timing cut, it just seems to run lower pressure fairly steady.
