Street/Strip Crankcase Vacuum using a PCV Valve
weedburner
Wa State
Here's the evac system I had been using. These valve covers are a circle track design that originally used a crossover tube with a couple small breathers, I eliminated the crossover setup and made some adapters to plumb them into a separator can that I had also installed a pcv valve into. The hose out the bottom is connected to a standpipe inside the separator, other end of that hose connected to the inlet of the electric pump. Outlet of the electric pump had a large header evac style check valve to eliminate the vacuum leak when the pump was not turned on. Using the pcv valve as a crankcase vacuum source worked so well that I rarely turned on the electric pump, got to the point that I considered the electric pump system as dead weight.
I ended up eliminating the hoses, separator, electric pump, and check valve. I replaced them with a modified version of the original crossover tube. Basically I made some Delrin check ball seats that fit inside the aluminum crossover tube's breather standpipes...
For the check balls, I bought some 1" dia nylon bearing balls, cost me around $5. I also installed my homemade adjustable pcv valve that had formerly been installed in the separator...
The plastic elbow on the pcv valve rotates, I pointed it off to the side and attached it to it's hose.
These check balls are pretty light-weight, launching the car does not cause them to become un-seated and leak crankcase vacuum.
Grant
Grant
Nice!
That first set up looks like it could suck a golf ball thru a garden hose.
"Crankcase vacuum"
Do you run a vacuum pump?
Most crankcases run at slight pressure even with a PCV
Grant
Interesting. So at high vacuum the balls cover the breather holes and at low vacuum the balls get out of the way and let crankcase pressure out of the breathers. Am I getting that right???
So no vacuum pump either? I’d like to test all that on a dyno and see what happens.
"Crankcase vacuum"
No vacuum pump at all with the 2nd picture setup, just a pcv valve sucking against a sealed crankcase. Crankcase vacuum is essential for my low tension rings on the street, an earlier version of this engine only got around 250mi to the quart before I sealed it's crankcase and added the pcv valve.
The pcv valve has been modified to make it work similar to adjustable orifice, currently set to draw around 12-15"Hg in the crankcase while cruising down the highway. Here's a RacePak graph showing crankcase vacuum during a 6.25sec long WOT 3rd gear pull with the pcv valve as the only vacuum source. Nitrous system was NOT turned on, this pull was NA.
...Red line- engine rpm
...Blue line- WOT switch
...Yellow line- crankcase vacuum
The pull started out with 12.6"Hg @ 2600rpm. When the pull ended at 6250rpm, even without the electric pump running the crankcase still had 3.9"Hg of vacuum left. I should add that the 355" engine is well sealed, no dipstick (oil level sight glass), Total Seal gapless top rings, and a 114 LSA nitrous cam.
When blowby exceeds the volume of the pcv, the check valves un-seat and any pressure is vented thru the breathers.
Grant
You got it right. The version before this had an electric vacuum pump as backup, but I rarely needed it. Decided to cut the extra weight and let the breathers be the relief.
Grant
Grant
Dam Boy
We need to change your handle to - Professor Vacuum
Nice job
It would be a lot of work to verify the benefits on a dyno, as the main benefit to me is being able to run lighter tension ring packs on the street. It's part of what helps me net 20mpg on the highway without an overdrive, not to mention less wear/tear on the cylinder walls. Easier to cool the engine too. I'm 3100rpm @ 70mph.
Grant
Grant
20 mpg - nice
But I am from MO you offer up a statement like that and you are going to have to show me some proof.
20 mpg - nice
Mileage was calculated using a gps tracking app on my phone, never bothered to hook up the speedo. Car is currently 2300lbs, 4spd manual, on radials with fairly good aero. TruTrac diff allows it to roll pretty free thru the corners. Low compression pump gas engine with nitrous, it'll also do 70mph in 1st gear :) Here's a link to the car's build page- http://grannys.tripod.com/20102.html
Grant
Grant
What the hell kinda A body is that!
Cant say that I am familiar with that one.
Grant
I was talking about monitoring crank case vacuum, but I forgot you are data logging.
Just sharing the breather/checkvalve thing, might work on an A-body too. For some Mopar content in this thread, here's a pic of a naked dirt latemodel I built back in the late '80's...
Won a few features, at the time it was the only Mopar at the track. The engine was a 440 BBM that was mounted backwards in the car. The homemade transmission's input shaft plugged into a hub that bolted onto the engine's damper. Backwards engine meant that the drivetrain spun backwards. Quickchange was modified to flip the spool, putting the ring gear on the other side of the pinion.
The car after that one was powered by a homemade 4 rotor rotary engine, it's what originally got me into the Mazda. Here's a link to that car's page and info, you will find the Mopar car at the bottom- https://grannys.tripod.com/4rotor.html
Grant
