2 273 ball Well-Known Member Joined Mar 12, 2016 Messages 648 Reaction score 59 Location hemet Jan 8, 2019 #1 Hi I m trying to loosen the brake hose that goes to the brake line, front brakes it is stuck Any ideas I might have to replace that small line ,
Frank Mopar Well-Known Member Joined Aug 14, 2011 Messages 1,464 Reaction score 927 Location Lackawanna, NY Jan 8, 2019 #2 Take the clip off the hose. Pull it down out of the bracket so you can turn the hose portion not the hard line fitting. Once hose is off you can free up the line fitting.
