1. cullenc101684
    cullenc101684 Member
    22
    0
    Oct 2, 2011
    Portsmouth, VA
    Local Time:
    12:13 AM
    When i got my new tires put on, when i got home i noticed one of my studs broke partially , how easy is it to replace it? Would a tire place fix it, if i ordered the parts? Do i even need to order the parts or would a tire place have various studs?? any help would be appreciated since im in the dark on this issue, it is a stock 5x 4 bolt pattern so i dont know if that helps or makes a difference at all. Thank you
  2. 1970Duster
    1970Duster Well-Known Member
    6,644
    93
    May 30, 2010
    Local Time:
    9:13 PM
    You can replace them yourself, but it would help if you said if it was the front or rear.
  3. Bulldozer
    Bulldozer free ice cream sandwiches
    14,986
    2329
    Oct 16, 2011
    behind the wheel
    Local Time:
    11:13 PM
    i have had great success knocking the studs out of the rear axle with a good sludge . the front drum or disc,not so much,had to have them pressed out.
  4. cudajim
    cudajim cudajim
    1,422
    65
    Jan 17, 2006
    Grass Valley, Ca.
    Local Time:
    9:13 PM
    I agree with 73abodee above. If it's a rear stud just beat it out with a mini-sledge. If it's a front one you'll have to get it pressed in at a machine shop unless you have a press.
  5. 805moparkid
    805moparkid Slant and AFX Guy
    11,498
    90
    Oct 29, 2008
    Anthem AZ
    Local Time:
    10:13 PM
    is it a drivers side?? or more importantly a left hand thread?? if so take it back and have them fix it... sounds like they broke it installing new tires...
  6. trapster
    trapster Well-Known Member
    2,672
    283
    Feb 19, 2009
    Central Florida
    Local Time:
    12:13 AM
    Careful I bent something on my front hub trying to remove a stud.
    Rear shouldn't be so bad, I used a socket and a heavy C clamp to push one out.
  7. BillGrissom
    BillGrissom Well-Known Member
    7,597
    495
    May 10, 2009
    Sacramento
    Local Time:
    9:13 PM
    Make them fix it. Tire monkeys should know about left-hand threads, but many don't. It wasn't just Mopar cars, many cars both domestic and foreign used LH studs. Goodyear idiots messed up a stud and didn't tell me. When the tread separated on the highway weeks later, I tried to remove the wheel and the stud just spun in the hub. The monkey must have kept turning up his impact wrench until he spun the stud.
    In early cars (1968 down?), the factory swaged the front studs to secure the drums. You need to file the swage off. You might cut the stud flush with a hacksaw and drill it out a bit to remove the swage. I have beat the studs out with a hammer in a junkyard to obtain a hub, which sheared the swage off.
  8. cullenc101684
    22
    0
    Oct 2, 2011
    Portsmouth, VA
    Local Time:
    12:13 AM
    it was drivers side front, drum brakes, so from what it seems i dont have such an easy issue on my hands. Should i order a new left hand stud and have a tire place fix it?, i dont wanna deal with the place that messed it up.
  9. trapster
    2,672
    283
    Feb 19, 2009
    Central Florida
    Local Time:
    12:13 AM
    There is a special swage removal tool that fits into a drill.
    Somebody should have more info on it.
  10. dustermaniac
    dustermaniac Senior Member
    6,181
    543
    Oct 23, 2009
    Modesto, CA
    Local Time:
    11:13 PM
    You can most likely get a replacement stud at NAPA
  11. Bulldozer
    14,986
    2329
    Oct 16, 2011
    behind the wheel
    Local Time:
    11:13 PM
    any autozone or oreillys has the studs in stock (usually) i have bought 10 at a time. its just a matter of getting your old one out, and then you have pull it through with a lug nut.
  12. moparlover
    moparlover Well-Known Member
    2,617
    24
    Dec 17, 2011
    hagerstown, md
    Local Time:
    12:13 AM
    might as well replace all 5 since you are at it
  13. Old Tired Rebel
    Old Tired Rebel Legandary Member Legendary Member
    12,164
    241
    Oct 10, 2009
    NC
    Local Time:
    11:13 PM
    Do you use any loctite when replacing wheel stud?
  14. seabee
    seabee FABO Gold Member FABO Gold Member
    2,488
    657
    Dec 20, 2009
    Bonita, CA
    Local Time:
    9:13 PM
    I replaced all of my Left Handed studs recently. The studs are cheap and the Hydraulic Press I bought ($70)gets used so much I don't know how I lived without it.
  15. Bulldozer
    14,986
    2329
    Oct 16, 2011
    behind the wheel
    Local Time:
    11:13 PM
    i never have Cliff.
  16. Old Tired Rebel
    12,164
    241
    Oct 10, 2009
    NC
    Local Time:
    11:13 PM
    Thanks.
