Subframe repair(large pic warning)
Suspension, Steering and Chassis
  1. Nick Mailloux
    Nick Mailloux Well-Known Member
    96
    45
    May 5, 2018
    Orting WA
    Local Time:
    8:34 AM
    I finally decided to tackle the cracked subframe on my 73 swinger. I cut out the bad metal on the bottom where the rear kmember nut is and removed the nut. I ended up internally sleeving it with a piece of 3 by 2 inch 3/16th wall steel tubing. I did 3 3/8ths plug welds on the inner side and 5 on the outer side. Drilled the ends of the cracks and beveled them with a carbide bit in my die grinder. Then welded it all up and ground it smooth. This seemed more daunting than it actually is.
    If anyone ever needs to do this, I took some pictures that may help show what I did. Make sure to measure 500 times and cut once!
    • Like Like x 12
    • Ironracer
      Ironracer Gearhead
      6,197
      4855
      May 8, 2020
      Tampa Bay Florida
      Local Time:
      11:34 AM
      Whoop ass Job Man!
      • Agree Agree x 5
      • Like Like x 1
      • Nick Mailloux
        96
        45
        May 5, 2018
        Orting WA
        Local Time:
        8:34 AM
        Thanks brother! It's been on my to-do list for way to long.
        • Thanks! Thanks! x 1
        • Ironracer
          Ironracer Gearhead
          6,197
          4855
          May 8, 2020
          Tampa Bay Florida
          Local Time:
          11:34 AM
          Right on Brother! Respect is Given, to a certain point, and Earned Afterwards. You, Sir, Have Earned mine! Honestly, that's a Slick Repair. Looks Strong as Heck
          • Like Like x 1
          • Agree Agree x 1
          • Nick Mailloux
            96
            45
            May 5, 2018
            Orting WA
            Local Time:
            8:34 AM
            Thank I really appreciate that. Frame work has always kind of freaked me out. I just grabbed the bull by the horns and did went for it. Turned out way better than I would have hoped for. I really learned that if I can do it, anyone with a welder and time could do it!
            • Ironracer
              Ironracer Gearhead
              6,197
              4855
              May 8, 2020
              Tampa Bay Florida
              Local Time:
              11:34 AM
              What size steel did you use fer boxing that in? 3/16"?
            • RustyRatRod
              RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
              86,578
              68950
              Jun 7, 2010
              Georgia
              Local Time:
              11:34 AM
              Looks really good, Nick!
              • Agree Agree x 2
              • Like Like x 1
              • harrisonm
                harrisonm Well-Known Member
                4,349
                5294
                Jan 16, 2005
                Topeka, KS
                Local Time:
                4:34 PM
                Great work, @Nick Mailloux . Quite impressive. Stop drilling the cracks is an excellent idea that a lot of people don't think about.
                I do have one question. In picture #5, I see what looks like the sleeve from #4 set into place. Are the pieces I see in pictures 6 & 7 the same parts as in 4 & 5 only with the nut installed and welded in?
                Congrats. Great repair.
                • Like Like x 1
                • Agree Agree x 1
                • Nick Mailloux
                  96
                  45
                  May 5, 2018
                  Orting WA
                  Local Time:
                  8:34 AM
                  3x2 3/16th wall. Went and measured and corrected my post!
                  • Nick Mailloux
                    96
                    45
                    May 5, 2018
                    Orting WA
                    Local Time:
                    8:34 AM
                    Thanks buddy!!!
                  • Nick Mailloux
                    96
                    45
                    May 5, 2018
                    Orting WA
                    Local Time:
                    8:34 AM
                    Yes it's the same piece, I was test fitting it, and then marking where I needed to drill the hole for the kmember nut. And absolutely, I always drill the starts and ends of stress cracks, all it actually does is prevent it from spreading during the welding process. Added bonus is they are additional plug welds! The rear of the tube extends into the frame about an additional 1/2 an inch too, so even if the cracks come back, it will still be safe. Nothing can move!
                    • Like Like x 1
                    • 72bluNblu
                      72bluNblu FABO Gold Member FABO Gold Member
                      12,610
                      7939
                      Nov 28, 2008
                      NorCal
                      Local Time:
                      8:34 AM
                      Nice work! :thumbsup:
                      Frame repair can definitely seem kind of daunting for sure, but really it's all just about measuring and making sure stuff stays where it's supposed to.
                      • harrisonm
                        4,349
                        5294
                        Jan 16, 2005
                        Topeka, KS
                        Local Time:
                        4:34 PM
                        I don't see those cracks coming back unless you try some General Lee jumps. Great work. You should include some text and make it a How To article.
                        • Like Like x 1
                        • Agree Agree x 1
                        • Ironracer
                          Ironracer Gearhead
                          6,197
                          4855
                          May 8, 2020
                          Tampa Bay Florida
                          Local Time:
                          11:34 AM
                          I'm just a Lowly Carpenter, but it looked like it was over an 1/8" and less than a 1/4".... just an edumacated guess..Awesome Job Man
                          • Kendog 170
                            Kendog 170 Let the boy go !
                            2,626
                            1971
                            Mar 10, 2016
                            Tewksbury Ma.
                            Local Time:
                            11:34 AM
                            Very nice thought out job.
                            • Agree Agree x 1
