Calling trick flow might be a good start.
Too hard,that would entail common sense....
It's all right here. Scroll down after opening link or read below:Any way to find out what the specs on the various offered springs are? "max .680 lift" and "hydraulic roller cam" doesn't tell me much...
The more I think about it I just may buy a pair cause the way it's going I won't be able to build what I want.A 600 horse 470 on pump gas with a 100 shot will be slow but won't have to work on it a lot.Next year I might run dragweek
Now I'm thinking of B1bs or ezI'm rounding up the parts for a pump gas 470 that will use the TF heads. I'm shooting for 650 hp with a 850 DP carb. It might make even more than that depending on how big of cam I slide in there.
440 Source CNC Stealth Airflow Results
Lift / Intake / Exhaust
.100" -.. 75.0 / 72.9
.200" - 156.7 / 124.8
.300" - 219.8 / 166.4
.400" - 266.2 / 198.1
.500" - 298.8 / 219.3
.600" - 314.9 / 233.3
.700" - 320.7 / 243.8
TRICK FLOW PowerPort 240 Airflow Results
.100" -.. 78 / 58
.200" - 154 / 130
.300" - 230 / 186
.400" - 282 / 222
.500" - 310 / 243
.600" - 326 / 253
.700" - 334 / 262
My MCH ported aluminum Mopar 452 heads flow 328/268 which is basically the same as the new Trick Flow heads. But those cost a lot more than what TF is pricing theirs at.
Are those Max-Wedge port size?my victor knock-offs flow 352 @ .600----------------------------
On Trickflow's Facebook page on the left side column they answered the guy above me and said it would be like Sept or Oct .... so I'm going to look at EZ's .... EDIT: just ordered EZ's from Muscle Motors with CNC work
Yeah...thanks summit for getting my hopes up by putting in your catalog.....
