[WANTED] Sun Water Temp Gauge
FYI- unless you already have one, the temp sensors for those are big money if you can find one.
Thanks, even the one gauge on EBay is big
Money for me.
Yep, and there's no guarantee. There is a product called Meter Match that may work. I'll be looking into it further when I install my blue line set up.
Analog Gauge Converter: MeterMatchTM
MeterMatch allows you to mix and match different gauges and senders, or to make gauges more accurate. It can be used with many gauges that have resistive senders - such as fuel, oil pressure and temperature gauges. In addition, it allows you to have low and/or high set-points that will trigger a bright, blinking, LED indicator to alert if the gauge exceeds normal values.
It is housed in a small (2.4" x 1.85" x .93") enclosure that can be located behind the dashboard near the gauge. Wire connections are made via a screw-terminal strip inside.
