[WANTED] Super six kickdown linkage
Arturo Lopez
Indio, California
Rating - 0%
0   0   0
Good afternoon, everyone.
I just had the good fortune of coming across an aluminum super six intake with carburetor at my local pick a part, but no kickdown linkage. Anyone have the kickdown linkage and bracket they're looking to sell? Thank you in advance for your replies!
You need more than just that one rod. The throttle cable bracket is unique for the 2bbl setup too. Add the pivot link, spring, and the slide link and you're most of the way there.
Lokar makes an after market throttle cable setup that can work. If you can’t find on the search on this site, check with the slant6 forum.
I was able to score the correct throttle bracket and rods off eBay. Took a long while, but someone finally posted what I was missing on there.
I don’t know if this helps, but here’s some closer pics of what will be needed.
Thanks for the pics and info! I'll wait and see if a complete set comes available, if not I'll try the lokar cable set up
