iprangenberg
Active Member
Help with “super six” set up. I just put a 225 super six in my 1971 Plymouth Scamp. I have all the correct parts, although I still have to change the accelerator cable.
The 904 transmission is shifting much too early.I’ve moved the shift rod all the way forward on the bottom transmission swivel, and it shifts too early. I moved the shift rod halfway back on the transmission swivel and it still shifts too early. I’ve tried six different settings and the shift from second gear to third gear is instant.
The transmission shifts great when I shift manually on the column shifter and I know that the transmission is in good condition. any thoughts are greatly appreciated.
