Is it as easy as it seems to install the Mopar SS or Mancini PS springs?
Jack up the car, put jackstands under the frame. Jack up the rear a bit to take the tension off the springs. Unbolt the shocks and u-bolts, unbolt the front of the spring, unbolt & remove the rear shackles.
Installation is the reverse. Snug up all the bolts, lower the car and tighten everything up to spec.
Is that it? Anything to watch out for?
