Supercharger Slant Builds
Slant 6 Engines
  1. Fredsgarage
    Fredsgarage Active Member
    38
    21
    Apr 24, 2019
    San Leandro, CA
    Local Time:
    5:29 PM
    Though it gets mentioned countless times, these Slant engines are almost built tough as stock to accept a Blower or Turbo application.
    I would like to go a clean Supercharger set up with my 225 Slant 64 Dart 4 speed and hopefully will hit the magic (for me) 300 hp numbers I desire. I have seen enough Early 63-66 Slant powered Darts to know this can be done. And really would like if this Supercharge Slant thread lived on its own. So we who are interested can start to dream, acquire, research, build and drive.
    First of all thanks to Torqstorm for coming up with a "bolt-in" kit for Slants. Good Marketing too. Sadly It wont fit my 64 Dart engine compartment, unless I modify the core support and hood latch and fan and more...so I will have to go custom. That's okay, I'll live.
    What I am looking for here is different street worthy combinations, utilizing EFI, Two Barrel Carbs or unique intakes like Gill Welding provides and find out how the install, parts lists and finally tuning and road manners went?
    Are you with me guys and gals?
    James
    • Like Like x 2
    • my68barracuda
      my68barracuda Well-Known Member
      993
      646
      Dec 6, 2009
      Indianapolis IN
      Local Time:
      8:29 PM
      I have had mpfi on the 68 Barracuda Slant Six for a couple of years. Took the car down for a complete rebuild this past winter.
      I am getting close to having it back together.
      Using a ported GM Vortec TB on a Clifford Intake that I machined the nitrous bosses on to accept fuel injectors. I also machined the fuel rail from rail stock. Has a MS 3 Pro ecu controlling fuel and ignition. Near term plan includes setting up to run on e85. Longer term plan is to mount a Eaton M90 to the engine.
      • Like Like x 9
      • lilnoah
        lilnoah Supercharged slant six with 4 speed and 8.25
        497
        200
        Dec 22, 2014
        Murfreesboro, TN
        Local Time:
        7:29 PM
        I did mod my hood latch it’s not that bad 25119DC5-57D1-49D1-8E24-99AB663B6609.jpeg
        • Like Like x 2
        • Agree Agree x 1
        • MiradaMegaCab
          MiradaMegaCab Well-Known Member
          971
          469
          Feb 5, 2011
          Long Island NY
          Local Time:
          7:29 PM
          :popcorn:
          • Like Like x 2
          • Agree Agree x 1
          • famous bob
            famous bob mopar misfit FABO Gold Member
            14,719
            5079
            Aug 14, 2011
            okla
            Local Time:
            7:29 PM
            Kick A$$ , NOW ABOUT THAT WIRING ----------
          • vitamindart
            vitamindart Well-Known Member
            1,136
            230
            Jun 11, 2010
            Vernon,Wisconsin
            Local Time:
            7:29 PM
            Very Cool! I still second guess if I should have gone MS on mine, the FiTech has worked great so far. just wasn't sure I could pull off the MS.
            maybe some day. would love to know more about your setup. do you have a build on here?
            • Like Like x 1
            • toolmanmike
              toolmanmike FABO Staff Staff Member FABO Gold Member
              45,075
              28833
              Jan 18, 2006
              Iowa
              Local Time:
              7:29 PM
              Dang I wish the slants had a 7 main bearing lower end. I am suprised more guys don't dump the basement out of them with only 4 mains.
            • my68barracuda
              993
              646
              Dec 6, 2009
              Indianapolis IN
              Local Time:
              8:29 PM
              IDKFS but I think the stability comes from the large diameter mains and bearings. I had read that the mains are the same diameter as a 440.
              • Agree Agree x 2
              • my68barracuda
                993
                646
                Dec 6, 2009
                Indianapolis IN
                Local Time:
                8:29 PM
                I do not have a build thread,,
                The MS has been good, I had one issue with RF interference and had to add shielding / reroute wires and that was resolved.
                What I like about MS is the ability to support MPFI and you pick and choose your own hardware. I have had this system for maybe 5 years now, even the throttle body FiTech was not as common back then as it is now.
                And I see that now FiTech has a universal MPFI kit. I am sure they are all good.
                What is impressive about the MS stuff, and I am speaking of the MS 3 Pro is that it is much more than just an ignition - fuel controller.
                It can be the controller for: cooling fans, traction control, delay box, and the list goes on and on.
                • Like Like x 1
                • Fredsgarage
                  38
                  21
                  Apr 24, 2019
                  San Leandro, CA
                  Local Time:
                  5:29 PM
                • Fredsgarage
                  38
                  21
                  Apr 24, 2019
                  San Leandro, CA
                  Local Time:
                  5:29 PM
                  Impressive body of work there my68barracuda. I am guessing MS =Mega Squirt ?
                  I have been in conversation with a guy who has put down some impressive performance with a Supercharged Slant. I am guessing that all the ground work you are doing will lead to amazing numbers and reliability as well.
                • Fredsgarage
                  38
                  21
                  Apr 24, 2019
                  San Leandro, CA
                  Local Time:
                  5:29 PM
                  Hey "Ill". Im not sure what might be different but it was Uncle Tony (who like me has a 64 Dart) that mentioned there was a lot a fabricating involved with the Torqstorm on our particular cars. He mentioned fan space and core support I believe. Which leads me to believe that your car is different? I don't want to hack that area up too much. Im hoping for near bolt on application once I have a supercharge bracket built. Oh yeah, then the tuning, more tuning, more tuning.
                  Friend's Dart uses a Paxton Novi 2000 blower, and a Holley Sniper with success.
                • RustyRatRod
                  RustyRatRod Weenie idiot loser. FABO Gold Member
                  57,435
                  26960
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  8:29 PM
                  I WISH I could remember where I read that the four mains were somehow an advantage. It made sense too. I cannot remember for the LIFE of me where I saw it. I think it was also talking about how stout the block was whether aluminum or cast iron. I just cannot remember where I saw it.
                  That said, let me pose this question. How many slant six basements have you seen dumped? I've seen a couple of them with thrown rods. One was still running, but I've never seen one with the crank blown out of the bottom due to broken mains. Have you?
                • my68barracuda
                  993
                  646
                  Dec 6, 2009
                  Indianapolis IN
                  Local Time:
                  8:29 PM
                  saw photos of one, there was a guy, went by Turboram over at .org.
                  was running huge boost in a slant, dumped the backend of the crank and TQ out on to the track
                • RustyRatRod
                  57,435
                  26960
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  8:29 PM
                  That's pretty cool man!
                  • Thanks! Thanks! x 1
                  • RustyRatRod
                    57,435
                    26960
                    Jun 7, 2010
                    Georgia
                    Local Time:
                    8:29 PM
                    Ok. I'll buy that. SO there's ONE......at least. But I have to wonder "what other engine" "ALL THAT" wouldda destroyed too? It wasn't just enough to kill a slant. That wouldda killed a lot of stuff, dontchya think?
                    • Like Like x 1
                    • lilnoah
                      497
                      200
                      Dec 22, 2014
                      Murfreesboro, TN
                      Local Time:
                      7:29 PM
                      My fabrication was taking the hood support out and putting a fan in front of the radiator. The hood support is not completely gone but cooling fan had to fit in front. The stock fan would not fit with torqstorm pulley added.
                    • toolmanmike
                      45,075
                      28833
                      Jan 18, 2006
                      Iowa
                      Local Time:
                      7:29 PM
                      It just looks like a weak link. I have some friends that run Rat motors on 60# of boost in 2 wheel drive pull trucks. The 7 main straight 6's are much stronger and can tolerate the pressure. Most boosted engines can't handle the piston dome and cylinder bore pressure. The cranks will hold up although they do pound bearings out.
                    • Fredsgarage
                      38
                      21
                      Apr 24, 2019
                      San Leandro, CA
                      Local Time:
                      5:29 PM
                      I’m not sure how good cooling will be with a pusher fan. Most people say it won’t work. You’ll have to let us know.
                    • slantsixdan
                      slantsixdan =..=
                      6,403
                      1504
                      Jan 7, 2007
                      Vancouver BC
                      Local Time:
                      5:29 PM
                      How 'bout a Slant-6 with Hyper Pak and supercharger? See here.
                      • Like Like x 1
                      • Charrlie_S
                        Charrlie_S Well-Known Member
                        2,756
                        641
                        Oct 17, 2005
                        Silver Springs, FL
                        Local Time:
                        8:29 PM
                        Along with the main cap(s) and saddle.
                      • my68barracuda
                        993
                        646
                        Dec 6, 2009
                        Indianapolis IN
                        Local Time:
                        8:29 PM
                        I remember seeing that photo posted at .org
                        Looked but could not re find it.
                      • RustyRatRod
                        57,435
                        26960
                        Jun 7, 2010
                        Georgia
                        Local Time:
                        8:29 PM
                        Re find. Is that kinda like un see?
                      • lilnoah
                        497
                        200
                        Dec 22, 2014
                        Murfreesboro, TN
                        Local Time:
                        7:29 PM
                        It works fine. I have the fan set up on a controller.
                      • Fredsgarage
                        38
                        21
                        Apr 24, 2019
                        San Leandro, CA
                        Local Time:
                        5:29 PM
                        Yes, I take one. LOL. Its going total some ingenuity to get it in my 64 Dart. But it will happen.
                        Slant Supercharged.
