swap 1996 318 EFI onto 1967 273?
Discussion in 'Small Block Mopar Engine' started by Dana67Dart, Mar 13, 2018.
  1. Dana67Dart
    Dana67Dart Most undignified way to get to Colorado!
    1,030
    333
    Jul 16, 2017
    Northern Colorado
    Local Time:
    7:52 AM
    Has anyone swapped the EFI intake, etc and electronics from a 90's 318 onto a 60s 273?
    Sure swapping the entire 318 could be done but what would the fun in that be?
  2. 65 Dartman
    65 Dartman FABO Gold Member FABO Gold Member
    9,076
    1250
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    9:52 AM
    I have thought about this myself. Subscribed!
  3. diymirage
    diymirage HP@idle > hondaHP@redline FABO Gold Member
    12,989
    5168
    Oct 12, 2012
    michigan
    Local Time:
    9:52 AM
    Are the bolt angles for the intake the same between those two motors?
    (I seem to remember the earlier 273s had a different bolt angle, but I don't recall the cut off)
  4. 65 Dartman
    9,076
    1250
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    9:52 AM
    The change was for 66 but if you used 66-later 273/318 heads it wouldn’t matter
  5. replicaracer43
    replicaracer43 Old school member
    3,473
    1657
    Oct 10, 2008
    View My Photos
    Local Time:
    8:52 AM
    What year fuel injection? The factory TBI was problem prone, would probably be a reliability downgrade from a well tuned carb. The 93 up magnum stuff is light years better, but not applicable to your 273
  6. Dana67Dart
    1,030
    333
    Jul 16, 2017
    Northern Colorado
    Local Time:
    7:52 AM
    1996 318 from a jeep grand Cherokee. Not TBI as I recall
  7. mvh
    mvh FABO Gold Member FABO Gold Member
    1,280
    102
    Dec 17, 2007
    Menlo Park, CA
    Local Time:
    6:52 AM
    Does the electronics require a crank position sensor? I don't know late model stuff at all, just thinking of potential hiccups.
    • Agree Agree x 1
    • replicaracer43
      3,473
      1657
      Oct 10, 2008
      View My Photos
      Local Time:
      8:52 AM
      Oh, didn't see that. But NO, intake won't bolt on, and no provision on rear of block to mount crank sensor.
      • Thanks! Thanks! x 1
      • replicaracer43
        3,473
        1657
        Oct 10, 2008
        View My Photos
        Local Time:
        8:52 AM
        Easier, faster, more performance would be swap in intire 318 magnum, although I understand that's not what you asked.
        • Agree Agree x 1
        • Dana67Dart
          1,030
          333
          Jul 16, 2017
          Northern Colorado
          Local Time:
          7:52 AM
          That's what I was looking for. I know 273 and 318 not 100% comparable but I don't know the differences over the years.
        • replicaracer43
          3,473
          1657
          Oct 10, 2008
          View My Photos
          Local Time:
          8:52 AM
          Magnum (93 up) went to a vertical bolt arrangement
        • Tooljunkie
          Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
          4,765
          3344
          Jul 22, 2017
          Manitoba
          Local Time:
          8:52 AM
          I would spend the money on a tbi system from holley or whatever. The 87to 93? Tbi systems are not considered tuneable by any means.
          The magnum immediately thereafter is much better, but as mentioned the transmission bellhousing has to be notched for the sensor. Manual and auto require different sensors.
          Flex plate/flywheel needs to be adapted to the 904.
          Engine/trans would be easier yet.
        • DionR
          DionR Well-Known Member
          1,722
          84
          May 7, 2008
          Spokane, WA
          Local Time:
          6:52 AM
          If Magnum heads would bolt on, and it was an auto, it would probably be easy to do. Not sure the 273 bore is big enough for the 1.92/1.625 valves.
          If the bore is big enough, bolting the heads on would allow you to bolt the intake on. After that, the last hurdle would be swapping the flex plate so the CPS would have notches to read, and then building a mount for the CPS.
          There is a place that sold a mount the used the trans bolts, for like $75 or something. I’ve also seen some one use a piece of angle bolt to the back of the head to create the flat plane needed to bolt the CPS to.
          Could all be done, provided the heads bolt on without conflicts with the valves.
        • DionR
          1,722
          84
          May 7, 2008
          Spokane, WA
          Local Time:
          6:52 AM
          Just occurred to me that bolting it on is only half the struggle. Still have to tune it so it runs right, which won't happen unless your swap is an OBD2 setup.
          Pretty sure a 96 GC is, but I would verify before putting much effort into it.
        • 67Dart273
          67Dart273 Well-Known Member
          37,149
          4891
          Oct 14, 2010
          Idaho
          View My Photos
          Local Time:
          6:52 AM
          1....You can NOT bolt a multiport magnum intake to any LA engine, and the manifold CAN NOT be redrilled.
          (If you spend enough time AND MONEY, you might be able to re-drill the LA heads for the magnum intake, but that would require removing the heads)
          2....Magnum head swaps have been done, don't know if practical on 273, due to compression.......would mag head drop comression? Don't know
          Go over to "Binder Planet" and read some of the ideas over there. Guys HAVE put injector bungs into carb manifolds and ran multiport injection with older manifolds.
          Magnum "stuff". You need a mag crank sensor setup which you will have to build. You are not going to be able to run the factory magnum flexplate on your 273, at least not without a lot of work
          In theory, you could run a mag distributor which provides the cam sync (not ignition trigger)
          speed sensor.........Not sure..........there were some TBI engines which used speed sensors which fit the early style transmissions, so "maybe" you could go with that. SOMEWHERE I found a NP435 truck gearbox out of a TBI truck which had the "same as" later speed sensor. AKA the speed sensor fit the 4 speed and worked with the factory TBI and could be used with newer multiport
          You could build up your own TBI.......get / find/ steal/ buy a TBI throttle body, buy a megasquirt unit. You don't need cam sync or speed sensor, and could trigger it from a Mopar electronic distributor.
          Find/ look/ wait a USED unit. I have an old Holley pro-jection, a Holley Commander 950 (I would sell electronics to that) Holley HP adapted to the Commander TBI, and have just bought an FItech TBI "used" off CL for about 1/2 the new price Yeah.........it's a gamble
          This all started in 2012
          Anyone know Holley Commander 950's? programming?
          This is the old Holley pro-jection. Computer works but not worth the trouble. GREAT candidate to upgrade to Megasquirt. Payed 75 bucks I think
          Used Holly Commander 950 I think I paid 300 bucks. Turned out to be a steal, you cannot find the TB unit for that on egag Only thing really wrong with these is they are not "self learning"
          Later, I upgraded the Commander to Holley HP for around 1300 "all new" from Holley, with HP computer, harness and O2 sensor. EITHER the Holley HP or the Commander computer (or Megasquirt) will operate EITHER TBI or multiport.
        • Dana67Dart
          1,030
          333
          Jul 16, 2017
          Northern Colorado
          Local Time:
          7:52 AM
          Thanks all for great input. I have laid the idea to rest now!
