firearrowsrs
New Member
I am looking to install a sway bar from a 70 dart into a 65 dart. looking for the braket welded to lower control bar. or do I fab it?
curious what you've done about the K-member mounts.I am looking to install a sway bar from a 70 dart into a 65 dart.
you're absolutely correct. I guess I'll pass on the sway bar.That70 sway bar is way to wide to fit into a 65 Dart. You’d be better suited to find a 65/66 sway bar or go with one of the aftermarket ones like Addco or Helwig that actually fit the early A
Finally looked and didn't realize how different the K's were.curious what you've done about the K-member mounts.
