Mack F-700
Member
Will a 15by7 with a 215/70-15 fit on a 74 dart Swinger
The fronts may fit (if that's what you are asking) The rears will fit with a 255 60 and a 4.25" backspace. A little tight but no trimming and lip rolling on my Swinger but has pretty stiff springs.Will a 15by7 with a 215/70-15 fit on a 74 dart Swinger
My '72 has 15x8 Wheel Vintiques Rallies in the back. Did have to roll the fender lip some. 235x60s if I member right. 4 5/8 backspace on them 15x8s
Dang that's a good lookin car!The fronts may fit (if that's what you are asking) The rears will fit with a 255 60 and a 4.25" backspace. A little tight but no trimming and lip rolling on my Swinger but has pretty stiff springs.
I have 225/70/14 on the rear of mine with 14" wheelsWow
Nice car. It was for the rear. I am changing my mind though. Would you know the biggest tire I can fit on an original 14by6 wheel for the rear. Im probably going with a 205/70-14 on the front
NiceSame as toolmanmike, but have steelies and I cut my fender lips to the pinch weld and used offset spring hangers for extra clearance.
Is 5.5 the factory width on a steelie ? That’s what I’m going to go with for nowI believe the biggest size one can purchase is a 225x70 14". That tire would fit no problem on a factory 5.5" wide rally or steelie rim. No clearance issues either.
Thanks, just to let you know I have Mancini XHD leaf springs with a 1" lowering block and have 1.03 torsion bars up front and lowered it till I liked the look, not sure how much.Nice
That’s the look I’m going for. I’m going to use stock wheels for now
Thanks for the info
