Synthetic 5w50 Schaefer oil
Small Block Mopar Engine
  1. Dartish
    Dartish Well-Known Member
    652
    356
    Sep 26, 2016
    Iowa
    Local Time:
    5:33 PM
    Anyone ever tried this stuff? I can get a decent deal on a case through work but never ran a 5w50 before. Currently running Mobil1 15w50 in my truck. Mild 360 doing a lot of towing and off roading. Like the 50weight after the engine temp gets up there, but thinking that 5w50 might be a good oil when she weather cools off. Looking at their website, it's a full synthetic, with high zinc level for flat tappet cams. Anyone have any thoughts or used Schaefer oil?
    • Thanks! Thanks! x 1
    • MOPAROFFICIAL
      MOPAROFFICIAL FABO Gold Member FABO Gold Member
      9,439
      8790
      Jun 1, 2016
      Oceanside ca.
      Local Time:
      3:33 PM
      I've used their oil for over 20 years.
      Seen first-hand lab testing of bearing wear microns per blah blah. Its good stuff.
      • Agree Agree x 1
      • Killer6
        Killer6 Well-Known Member
        2,933
        1057
        Mar 9, 2015
        PA
        Local Time:
        5:33 PM
        Mobile1 used to come in 5W50, and I ran it in My ShelbyZ year 'round, now it's 15W50.........but the car never see's the road in the winter months now...I'd use it........
      • TrailBeast
        TrailBeast AKA Mopars4us on Youtube
        21,684
        9623
        Mar 11, 2011
        Arizona
        Local Time:
        4:33 PM
        Where you live I think I would use a decent normal oil of about 10/30 -10/40 range if it were my truck and an LA motor.
        5.9 I use full synthetic 5/30 because those motors are made for synthetic and it isn't all about pressures.
        A truck with generally low speeds and higher temps can benefit from a fast running oil that helps carry off heat and the synthetics do that.
        • Like Like x 1
        • nm9stheham
          nm9stheham Well-Known Member
          12,089
          3979
          Dec 20, 2013
          Waynesboro, VA
          Local Time:
          6:33 PM
          Interesting on the Schaefer oil; thanks for the info. (I hope it is better than their beer LOL)
          I cannot see the actual zinc levels from their data sheets; have you found that info, OP? I can just find a general statement on 'extra zinc anti-wear additives....'.
        • Dartish
          652
          356
          Sep 26, 2016
          Iowa
          Local Time:
          5:33 PM
          We've got a Schaefer rep that comes into work. I've got her checking on the specific zddp levels. I'll let you know as soon as I hear from her. She just sells the stuff. You know the game, hire a beautiful woman to go around selling your oil and grease products.
          • Like Like x 2
          • Agree Agree x 1
          • fishy68
            fishy68 Tyr Fryr's Inc.
            16,586
            967
            Jan 11, 2005
            Central, IL (Hooterville)
            Local Time:
            5:33 PM
            I go to church with a Schaefer sales rep and he showed me some pretty convincing info on how well it works and tried to come up with a number for the ZDDP level a couple yrs ago but couldn't. Seems to be a secret. Dartish let us know what your rep finds out
          • Dartish
            652
            356
            Sep 26, 2016
            Iowa
            Local Time:
            5:33 PM
            Hoping to hear back from her Monday or Tuesday. I'll post whatever she comes back with
            • Like Like x 1
            • famous bob
              famous bob mopar misfit
              19,857
              8843
              Aug 14, 2011
              okla
              Local Time:
              5:33 PM
              if she`s beautiful, post a pic of her ! Back to the oil. When we ran the hemi for 14 yrs., we used who ever would furnish oil for us, didn`t seem to make a tinkers dam what brand, always ran 40 or 50 weight, course the hemi`s were set up loose back then.
            • seabee
              seabee FABO Gold Member FABO Gold Member
              2,488
              657
              Dec 20, 2009
              Bonita, CA
              Local Time:
              3:33 PM
              I'm not an oil expert but wouldn't 45 points of viscosity index improvers (VI) lead to a shorter service life?
            • nm9stheham
              12,089
              3979
              Dec 20, 2013
              Waynesboro, VA
              Local Time:
              6:33 PM
              Yes, for straight petroleum oils; they tend to cause rings to gun, etc.
              Buuuuut... Synthetics naturally have a wide temp range over which the viscosity is quite stable. They need little (maybe no) VI's to achieve those wide viscosity ranges; it is just in their nature.
              • Like Like x 1
              • Agree Agree x 1
              • Dartish
                652
                356
                Sep 26, 2016
                Iowa
                Local Time:
                5:33 PM
                Schaefer rep said the 5w50 has 2200ppm zddp per quart
              • Dartish
                652
                356
                Sep 26, 2016
                Iowa
                Local Time:
                5:33 PM
                A case of 12qts ended up costing $79. Didn't think that was too bad if it's as good as they claim it is. Sounds like it has a pretty good additive package
                • Agree Agree x 1
                • fishy68
                  16,586
                  967
                  Jan 11, 2005
                  Local Time:
                  5:33 PM
                  On their website it has a place to submit a question and I asked about the zddp package and this was their response
                  08/21/17
                  A: [Great question! Zinc 1600-2000 ppm phosphorus 1300-1900 ppm]
                  • Agree Agree x 1
                  • QKFSH67
                    QKFSH67 Well-Known Member
                    261
                    106
                    Dec 21, 2015
                    Prophetstown, IL
                    Local Time:
                    5:33 PM
                    It's great oil. Ran it on the derby track for years. Extreme heat,no water, it would never break down and lose its consistency after a long hard run on the track. Some cheap oils would look like cooked grease that you fried in the frying pan.
                    • Like Like x 1
                    • BoogieMan67
                      BoogieMan67 FABO Gold Member FABO Gold Member
                      316
                      151
                      Dec 24, 2016
                      Tennessee
                      Local Time:
                      5:33 PM
                      I run it in my 67 dart 225 6 10w30
                    • yellow rose
                      yellow rose Overnight Sensation
                      28,501
                      25174
                      Jun 19, 2015
                      Central Washington
                      Local Time:
                      3:33 PM
                      Don't forget...too much zinc is a power killer. High zinc oils are ok if you're not looking for power. Zinc is a power eater. IMHO, anything over ~1600 is overkill.
                      The big thing is to get you oil tested often enough to see how fast you use the additive package. When it's gone, it's time to change the oil. Mileage is a variable. Some engines use more additive quicker. An example would be a SFT with rockers that are not roller in the shafts. You have a bunch of area where the zinc gets used up.
                      A roller crammed engine, with rollers on the rocker shaft need less zinc and use it slower.
                    • Dartish
                      652
                      356
                      Sep 26, 2016
                      Iowa
                      Local Time:
                      5:33 PM
                      Mild, hydraulic flat tappet 360 in a truck that sees ALOT of mud and snow. Sustained load and rpm while toying around get it warm now and then. More interested in longevity then every last horsepower. I've liked the 50 weight and this stuff sounds like a decent oil and flows quicker then the dino oil when it gets cold in the mornings
                    • yellow rose
                      28,501
                      25174
                      Jun 19, 2015
                      Central Washington
                      Local Time:
                      3:33 PM
                      Then you are a good candidate for a very high zinc oil. Test a sample new and then test again every 5000 miles or so and see how fast you are using the additive package. Then you'll have your drain interval.
                    • Dartish
                      652
                      356
                      Sep 26, 2016
                      Iowa
                      Local Time:
                      5:33 PM
                      They said I can send in several samples for free since I just switched all our loaders and equipment over to Schaefer. I doubt I'd ever see 5000 miles on it anyway. I'm one of those guys usually changing it every 2000 or so, just because I like to beat the snot out of it on a regular basis. All my hunting and fishing spots are pretty hard to get to, and there's always someone around that needs their Z71 or Super Duty pulled out of somewhere by my rusty old dodge
                      • Like Like x 1
