1. Mopar Sam
    Mopar Sam Well Fed Member
    200
    77
    Jul 18, 2008
    Indiana
    Local Time:
    11:30 PM
    I put a stroked 5.7 in my wife's satellite [sorry,not an a body]. I used the tach signal from the MSD Hemi6 to trigger the FAST EZEFI. How do I hook up the tach? Can I trigger it from the same wire without affecting the efi?
  2. Steven190
    Steven190 FABO Gold Member FABO Gold Member
    786
    335
    Jan 13, 2012
    Omaha
    Local Time:
    11:30 PM
    I am not familiar with this box. I hope that someone can help. Just my thought is that there maybe interference if you connect the two wires. The only thing I have is I used a 6 AL with the Fast and used different wires for the ECU and the tach.
    Good luck on your project.
  3. General Disarray
    General Disarray Well-Known Member
    164
    118
    May 4, 2018
    South Park
    Local Time:
    10:30 PM
    Why don't you call the FAST or MSD tech support?
  4. billccm
    billccm Well-Known Member
    84
    50
    May 13, 2018
    Tucson
    Local Time:
    9:30 PM
    I would assume both inputs are high impedance, so yes both inputs can share the same signal wire.
  5. Mopar Sam
    200
    77
    Jul 18, 2008
    Indiana
    Local Time:
    11:30 PM
    Yeah, I guess that is what I will do.
  6. Mopar Sam
    200
    77
    Jul 18, 2008
    Indiana
    Local Time:
    11:30 PM
    I hope you are right. I know the EZEFI is sensitive to electronic noise. I was hoping some one on here had already one this. When I find out for sure I will post.
  7. billccm
    84
    50
    May 13, 2018
    Tucson
    Local Time:
    9:30 PM
    I recently used a oscilloscope to measure the msd tach signal. It's a clean, stable 24% duty cycle square wave. Voltage peak to peak is right with the battery.
    If the signal gets loaded down you could add a 10K pull up resistor, but I doubt you will need it.
  8. billccm
    84
    50
    May 13, 2018
    Tucson
    Local Time:
    9:30 PM
  9. Map63Vette
    Map63Vette Well-Known Member
    1,519
    25
    Apr 19, 2010
    Lawrence, KS
    Local Time:
    11:30 PM
    I'm splitting the tach signal to run my Megasquirt and my column mounted tach and haven't had any issue so far. I had originally tried to use the ignition output of my Megasquirt to run it, but it was easier to just use the signal straight from the MSD box.
  10. Mopar Sam
    200
    77
    Jul 18, 2008
    Indiana
    Local Time:
    11:30 PM
    Thanks! I think I will try it.
  11. Peter Bates
    Peter Bates 1973 Cuda owner for 36yrs
    137
    107
    Aug 25, 2018
    Sylvania ohio
    Local Time:
    12:30 AM
    If you have a obd port for the computer on your hemi you could buy a Dakota digital interface unit. It has two signals for the tach. That's how I was able to get a clean signal from my CPU to my speed hut tach. Now I just need to get a signal to my tcu tranny controller. I tried to no avail to pull a signal off the motor
  12. Mopar Sam
    200
    77
    Jul 18, 2008
    Indiana
    Local Time:
    11:30 PM
    No obd. It is a FASTEZEFI multiport system. I got sidetracked on some other projects and haven't done anything on it yet. I just set her rev limiter to 6500.
  13. 408 swinger
    408 swinger FABO Gold Member FABO Gold Member
    639
    430
    Nov 12, 2010
    Iowa
    Local Time:
    11:30 PM
    Update?
  14. Buschi340
    Buschi340 Well-Known Member
    1,263
    25
    Feb 19, 2005
    Wilhelmshaven, GERMANY
    Local Time:
    4:30 AM
    so you can use that one Output cable to run for example 2 tachs?
  15. Map63Vette
    1,519
    25
    Apr 19, 2010
    Lawrence, KS
    Local Time:
    11:30 PM
    As far as I'm aware you can. It's just a square wave signal and it's not meant to carry power, just voltage level. Pretty sure tachs would be high impedance devices that have large input resistance so they don't have a big power draw. I'm sure the output line is limited in what it can supply though, so if you stacked enough things together I could see it potentially being a problem. I don't think you'd have issue running two things though.
    • Agree Agree x 1
    • Buschi340
      1,263
      25
      Feb 19, 2005
      Local Time:
      4:30 AM
      will figure that out this winter. just two tachs, not an endless amount of tachs.. :) The one in the dash is hard to read sometimes
    • famous bob
      famous bob mopar misfit
      11,507
      2907
      Aug 14, 2011
      okla
      Local Time:
      11:30 PM
      I DON`T REMEBER OFFHAND , BUT I DIDN`T HOOK BOTH UP TO THE BOX, THINK FAST SAID NOT TO. Call fast and ask for Dave.
