Tailpipes with mini tub
69GT
Detroit area
I had my 69 Dart mini tubbed and there is no longer any room for a tailpipe on the passenger side. Has anyone come up with a way to still have tailpipes after your car was mini tubbed?
inertia
Victoria B.C. Canada
My son's Mopar tips are about an inch outboard of stock location, tubbed, sneaking out over spring, and back in again at the back .
They are 2 1\2* .
I'll try and get a pic, but there's an example here, on site if you do a "search" .
He'd like to do it different, if he did it again .!
Cal Tonsley
Australia
Mines tubbed with original style tank and 3” system with tailpipes exiting outside the springs. The last photo will give you an idea of how the pipe is routed on the passenger side.
69GT
Detroit area
Being the tailpipes are no longer hidden behind the frame rails, how visible are they from the side of the car when looking in the direction of the rear wheel wells?
RustyRatRod
I was born on a Monday. Not last Monday.
Georgia
Coyote Jack
Member #55, I'm old
Baxters Corner N.B. Canad
I have a mini tub with the springs moved inboard under the framerail. The exhaust is 2.5 inch with stock tips. I had the tailpipes made by a local shop for $300 plus taxes. Sure made a big difference in the noise inside the car. Tires are Nitto 325-50-15's on 15x10 wheels with 6.5 inch backspacing. Lots of clearance everywhere for exhaust and tires.
Jack
69GT
Detroit area
"I have a mini tub with the springs moved inboard under the framerail. The exhaust is 2.5 inch with stock tips. I had the tailpipes made by a local shop for $300 plus taxes. Sure made a big difference in the noise inside the car. Tires are Nitto 325-50-15's on 15x10 wheels with 6.5 inch backspacing. Lots of clearance everywhere for exhaust and tires.
Jack"
Do you have any pics of the tailpipes from underneath? Looking at some of the other pics I got the impression that the tailpipes would have to be moved to the outside corners but I would like to have tips in the stock location if possible.
Demonx2
Michigan - near Detroit
Coyote Jack
Member #55, I'm old
Jack"
I'll see if I can get some photos from underneath tomorrow. Mine are not in the stock location. When you move the springs inboard you can't run the exhaust directly underneath the framerails. Mine are on the outside edge of the framerail.
Jack
Coyote Jack
Member #55, I'm old
Here you go. A little tough getting good photos as I have the car put away for the winter. I was able to get them though and the first 3 are of the drivers side and then the passenger side. Added a picture of where the car is sitting.
Jack
69GT
Detroit area
Jack
Thank you for the pics.
