canadian duster
Hi all, its not an abody, but i suspect you will have the answer. I'm attempting to install an a833 from a 71 dart (a body tailhousing) into an 84 d150 1/ton. I knew the tailhousings were shorter on an a body, but assumed/thought the cross member mounting pad would be the same on all tailshafts. the pad on this housing ends up being a few inches short (insert jokes here)
can anyone help me understand if the crossmember pads changed throughout the years on the a833, or if i potentially have the whole set 2" forward of where it should be (which puts my engine into the firewall).
