Probably a no brainer for most of you Mopars enthusiasts, but I'm not most...
Can someone who knows Dusters tell me if the tie rod adjusters on 73 and up are longer than the tie rod adjuster on the 70-72 year Dusters? The 70-72tie rod adjuster measures around 8 inches in length.
My Duster is a 71 H code that had been converted to '73 front disc brakes and it's short on the tie rod adjustment.
Thank you!
P.S. I apologize if I'm not in the correct forum for my question.
Thank you!
