I'm doing some work on a 1973 Duster and noticed that the high beam indicator light does not come on when the high beams are turned on via the floor switch. I suspect the bulb is burned out in the dash. Unfortunately, I have somewhat larger hands and can't easily get to the bulb with my hand to twist it out of the cluster to change it. Does anyone have a technique they can share to get to this bulb to change it?
