The City said YES!!
General Discussion
  1. Red63440
    Red63440 Olddawg
    531
    524
    Dec 13, 2011
    Batavia, NY
    Local Time:
    9:49 PM
    I have done a lot more with a lot less.
  2. 1973Barracuda
    1973Barracuda Well-Known Member
    2,024
    2292
    Dec 11, 2009
    Local Time:
    9:49 PM
    Ceiling Height? I ask as my garage, 1800Sqft, is fabulous, except.......
    when built by the previous owner, put in a 9.5 ceiling. I will have to do surgery for a lift. Even if you aren't planning a lift now, I would engineer the clearance in an area for one.
  3. kursplat
    kursplat FABO Gold Member FABO Gold Member
    3,818
    2732
    Aug 24, 2010
    so cal
    Local Time:
    6:49 PM
    i thinking you'll have no problem finding ways to use all that space :thumbsup:
  4. mygasser
    mygasser FABO Gold Member FABO Gold Member
    961
    620
    Aug 17, 2010
    faversham, kent. united kingdom
    Local Time:
    8:49 PM
    agreed, but if it's not an option put in an inspection pit before laying the floor slab. make sure it's long enough to get out without having to roll the car back or forward too.
    neil.
  5. kursplat
    3,818
    2732
    Aug 24, 2010
    so cal
    Local Time:
    6:49 PM
    they won't let you do inspection pits here, don't want you dying because you left the car running and didn't ventilate :BangHead:. some people have done one after the garage was built. easiest way is get the contractor to pour the slab thin in the area you're planning to dig out.
  6. Red63440
    Red63440 Olddawg
    531
    524
    Dec 13, 2011
    Batavia, NY
    Local Time:
    9:49 PM
    They have been outlawed for a very long time.
  7. mygasser
    961
    620
    Aug 17, 2010
    Local Time:
    8:49 PM
    yes, you need planning approval here in the uk for a pit too. i know guys who do the pit, then lay the slab over it with plywood sheets just an inch or so below the surface covering the pit. easy enough to open it up after inspection then.
    there should be a way round the choking yourself risk, like motion sensors in the pit that switch on an extractor fan one end for the whole time you're in there working along with another at the other end feeding fresh air in. shouldn't be hard to build in at the start.
    neil.
  8. kursplat
    3,818
    2732
    Aug 24, 2010
    so cal
    Local Time:
    6:49 PM
    there are so many rules about ventilating an underground substructure, you'd never want to deal with it
  9. SLOPAR72
    SLOPAR72 Well-Known Member
    2,748
    2275
    Jan 5, 2016
    Richmond, VA.
    Local Time:
    9:49 PM
    Not sure if you are finishing your walls but something to consider is running conduit outside of the finished walls. It's not for everyone and we all have a different vision of the appearance inside their shop so to each his own. However this gives you access to changes in power needs if necessary without going into the walls. I am also a fan of lengthy SO cord (properly sized for the required power need) as it allows extreme flexibility and can easily be rolled up and hung on the wall....
    JW
