Installed new fuel sender. Looks like that was the problem.
It still reads low. This is with 5 gal. I might pull the sender and try bending it down a little or maybe messing with the gauge next time the cluster is out. I'm just happy I can at least monitor gas level at all at this point.
Also installed and tested new wiper and backup light harness.
All the electrics work now. When I got it home just the amp meter worked.
Just about ready to start taking it to shops for this and that.
Should be ready for up and coming cars and coffee in the spring.
, and chipping a little paint off the fender and door that I'll have to touch up, I finally got it aligned. Shuts great now. Unfortunately since a P.O. put on that 69 stripe with a misaligned door the stripe doesn't line up right.
