Welcome,to the world of engine rebuilders.There is no"zero deck" piston.Not cost effective for parts manufacterers to make more than 1 or 2 part numbers.You could yank the heads,measure the deck heighth on all 8 bores,then order pistons.Then deck the block equally parallel,in reference to the crank center line .This will get you close,assuming all 8 rods are same size,end to end .
