Thermoquad metering rod adjustment ?
Fuel and Air Systems
  1. rustytoolss
    rustytoolss Well-Known Member
    1,801
    43
    Sep 26, 2013
    Clinton, Ohio
    Local Time:
    1:43 PM
    Does anyone know what the setting is for the metering rods on a thermoquad. I've got the small TQ that has the 1 3/8" primary bores. 9371S , 1981 dodge truck 318
  2. dart4forte
    dart4forte FABO Gold Member FABO Gold Member
    4,157
    570
    May 28, 2004
    Mesa, AZ
    Local Time:
    6:43 PM
    You talking about the set screw that raises and lowers the metering rods?
  3. rustytoolss
    1,801
    43
    Sep 26, 2013
    Clinton, Ohio
    Local Time:
    1:43 PM
    Yes, is there an adjustment spec, or procedure? There is no information in my rebuild kit.
  4. RustyRatRod
    RustyRatRod 30 Degrees Outta Whack FABO Gold Member
    48,494
    14412
    Jun 7, 2010
    Georgia
    Local Time:
    2:43 PM
    Yes. Depress the metering rod primary piston until it lightly bottoms in the bore. Hold it there. With a small screwdriver, turn the screw counter clockwise until the primary piston stops going down. Then, slowly turn the screw clockwise taking note where the primary piston starts to move up. From the point it begins to move up, turn the screw 1 1/2 turns clockwise. This is a starting point. From there you can fine tune it by turning the screw clockwise to richen the mixture and counter clockwise to lean it.
