this horse has been beat to death , but------
Big Block A body Tech
  1. famous bob
    famous bob mopar misfit FABO Gold Member
    15,351
    5532
    Aug 14, 2011
    okla
    Local Time:
    6:18 PM
    I have had a rear mainseal leak since day one , I have finally found out why, after 3-4 times trying to fix it .
    The main seal cap is not made right, or the bolt holes in the block are offset from perfect, or the crank is setting in the block crooked . Don't think it the crank cause all pistons were exactly the same deck heigth when built , if crank was crooked one side would be off , compared to the other side. I installed the main cap after cleaning it up w/o the side seals , letting it center itself on the crank , ( no bolts) , one side of the cap is way closer to the block than the other side . I redrilled the bolt holes out bigger and checked the bolts , they (allen heads) were .005 bigger than stock , slightly adding to the problem.
    I still haven't figured out how to seal the cap on the sides , w/ the engine in the car ,
    getting the whole mess clean of all oil would be a bitch , not to mention how to get sillicone up in there to seal it from the outside.
    I have found a billet main cap that is offered by an old funny car racer, and not like the current ones on the market, ordered it this morning. If its the same way , sealing the sides will be a bithch , 73 yrs old and laying on a piece of cardboard in the floor aint fun any more !
    Sorry for the long rant m "more to come !"
    • Like Like x 3
    • Donnie514
      Donnie514 FABO Gold Member FABO Gold Member
      228
      100
      Mar 23, 2019
      Hartville, Ohio
      Local Time:
      7:18 PM
      OK, this is a big block...right?
    • krazykuda
      krazykuda Well-Known Member FABO Gold Member How-To Section Editor
      51,761
      16413
      Aug 20, 2007
      Orland Park, IL
      Local Time:
      6:18 PM
      If you replace the main cap, it has to be remachined to match your engine - align bored... You will have to pull the engine out and strip it down to the block to get it machined... When they machine a block, they rough bore the caps and mains, then bolt them together and align bore the crank bores so they are all lined up properly - that's why you can't mix and match the caps and have to keep them in the proper order that they were machined on the block....
      • Like Like x 2
      • Agree Agree x 2
      • krazykuda
        51,761
        16413
        Aug 20, 2007
        Orland Park, IL
        Local Time:
        6:18 PM
        Oh yeah, big blocks have that funny rear seal, not like the small block....
        You may not have to get it machined if it's a big block... I'm more familiar with small blocks...
        • Like Like x 1
        • toolmanmike
          toolmanmike FABO Staff Staff Member FABO Gold Member
          46,889
          31163
          Jan 18, 2006
          Iowa
          Local Time:
          6:18 PM
          Somebody makes a rear seal retainer to address this.
          • Like Like x 1
          • MOPAR4Me
            MOPAR4Me FABO Gold Member FABO Gold Member
            887
            173
            Jun 29, 2012
            Orange County, CA
            Local Time:
            6:18 PM
            Not sure but think this may be what you are referencing:
            Mancini Racing Billet Rear Main Seal Retainer
            "Fits: Big Block, Mopar
            Billet aluminum rear main retainer. It uses double o-ring on each end to seal the cap to the block. This retainer is designed to hold the proper diameter to clamp the rear main seal properly.
            Sold in kit form with Cap, 4-O-ring seals, Rear main seal, 2 - alignment pins for easy installation and socket head bolts"
            • Like Like x 2
            • Thanks! Thanks! x 1
            • MOPAR4Me
              887
              173
              Jun 29, 2012
              Orange County, CA
              Local Time:
              6:18 PM
            • MOPAR4Me
              887
              173
              Jun 29, 2012
              Orange County, CA
              Local Time:
              6:18 PM
            • mycuda
              mycuda FABO Gold Member FABO Gold Member
              5,516
              2820
              Feb 15, 2011
              Chicago/ Metro
              Local Time:
              6:18 PM
              Have to agree. Although didnt verify your
              Observations.
              I built this B block back in 1992.
              383 .60 over nothing fancy 11:1 open chamber ported heads.Gear drive.
              This thing leaked from day one. Interesting.
              Mainly after 30 minute drive or so.
              Nitrous playtime sure didnt help.
              But engine strong.
              I didnt want to think something I did or didnt do....
            • Darter6
              Darter6 Well-Known Member
              4,041
              1286
              Jan 16, 2008
              Nevada
              Local Time:
              4:18 PM
              Confucius say, It ain't a MOPAR if it don't leak !:lol:
            • fklskv
              fklskv Well-Known Member
              1,088
              562
              Aug 14, 2011
              Lackawanna, NY
              Local Time:
              7:18 PM
              • Thanks! Thanks! x 2
              • famous bob
                15,351
                5532
                Aug 14, 2011
                okla
                Local Time:
                6:18 PM
                The engine came out of as 66 Chrysler still mated to the trans, it had a rear main leak when I tore it down, which I didnt pay much attention to because I was not going to use anything but the block. Anyway, I have found that the cast rear maim seal cap is .061 shifted to the pass side , . Waiting on new one --------
              • mycuda
                5,516
                2820
                Feb 15, 2011
                Chicago/ Metro
                Local Time:
                6:18 PM
                Interesting.
                My 383 was out of 67 New Yorker....
              • famous bob
                15,351
                5532
                Aug 14, 2011
                okla
                Local Time:
                6:18 PM
                My deck height only had to have .003 taken off to be perfect , I think the machine work on the early blocks might have been real close . ??????????
                Cast main seal cap , not so much.
              • toolmanmike
                46,889
                31163
                Jan 18, 2006
                Iowa
                Local Time:
                6:18 PM
                I always heard the Chrysler engines were carefully assembled. More like they were factory blueprinted.
              • famous bob
                15,351
                5532
                Aug 14, 2011
                okla
                Local Time:
                6:18 PM
                I know they have been way closer to perfect than any of the chevy blocks I`ve messed with, they have been off a mile from what the factory said.
                The two 426 hemi`s I had were spot on perfect !!
                • Like Like x 1
                • RPMagoo
                  RPMagoo Just An Old Motorhead
                  3,035
                  1515
                  Nov 4, 2015
                  N.E. Pa.
                  Local Time:
                  6:18 PM
                  -- Same here, at 75. -- Amen Brother.
                  • Agree Agree x 1
                  • RAMM
                    RAMM Well-Known Member
                    1,638
                    1305
                    Nov 22, 2010
                    Ontario, Canada
                    Local Time:
                    7:18 PM
                    Yeah that would be me, I haven't had another big Mopar leak since. J.Rob
                    • Like Like x 1
                    • MOPAR4Me
                      887
                      173
                      Jun 29, 2012
                      Orange County, CA
                      Local Time:
                      6:18 PM
                      May have missed it, but aside from the cast rear main seal cap shift issue, is your install past/planned also including the seal position rotation offsetting in relation to the seal retainer/block flange mounting area?
                    • w2dart
                      w2dart Member
                      22
                      2
                      Mar 19, 2015
                      hayes, Va.
                      Local Time:
                      7:18 PM
                      I built one years ago. 3-4 rear main seals later, found out it was a marine engine reverse rotation. Pulling oil out of engine.
                    • famous bob
                      15,351
                      5532
                      Aug 14, 2011
                      okla
                      Local Time:
                      6:18 PM
                      Well I haven`t got the pan back on yet , but the new seal cap came in yesterday , and is the neatest I`ve ever seen. CNC`d and fit like a glove, couldn`t have been any more perfect, centered the maim seal , fit the side of the block perfect and tite both sides.
                      I was kinda worried about the side rails tho , as tite as it fit the block . I got the bright idea of glueing the soft rubber side rails to the cap , using DAP fusion weld, a fast setting , glue anything ''but pure silicone'' , glue.
                      Held it on a flat surface for about 15-20 seconds in position while setting up, oiled the sides of the rails when installing, had to apply a little push in pressure on one side to get started, went in w/ a good amount of pressure to install, when it hit the circular part around the crank , I had offset about 3/8" , I could tell it pushed them together to mate, really happy w/ it ---------reworked the funny car windage tray to fit the reworked funny car pan , will install it today. Mwuay old ass wore out -----------more to come.
                      • Like Like x 3
                      • oldkimmer
                        oldkimmer FABO Gold Member FABO Gold Member
                        14,031
                        3457
                        Nov 11, 2006
                        Kindersley, Saskatchewan,
                        Local Time:
                        6:18 PM
                        Glad to hear everything is working out. Kim
                      • famous bob
                        15,351
                        5532
                        Aug 14, 2011
                        okla
                        Local Time:
                        6:18 PM
                        PUT THE PAN AND WINDAGE TRAY ON TODAY, GOT THE RACK AND PINION BACK IN , JUST NEED TO GET A GOOD FILTER AND ADD OIL NOW. CAN EVEN RUN A REGULAR FILTER NOW AFTER REWORKING THE FAN SHROUD , HAVE HAD TO RUN A SHORT FILTER UP TO NOW.
                        I DID CHUCK THE FRONT MAIN STUDS UP IN MY LITTLE LATHE AND SHORTEN THEM, I CAN GET THE PAN OFF NOW W/O TAKING THE RACK AND PINION /STEERRING STUFF LOOSE .
                      • famous bob
                        15,351
                        5532
                        Aug 14, 2011
                        okla
                        Local Time:
                        6:18 PM
                        update/ got around to driving it yesterday, no leaks ! I highly recommend junking the stock main seal cap and buying a cnc`d billet one . About anybodies will probly work.
                        First time I haven`t had a leak on this 52 yr old barracuda !!---------fingurs crossed !
                        • Like Like x 1
                        • fratzog lover
                          fratzog lover Well-Known Member
                          13,209
                          10594
                          Jun 7, 2013
                          Maple Shade New Jersey
                          Local Time:
                          7:18 PM
                          The 383 had 2 different rear main seal journals. The knurled journal likes the original style seal.
