Thoughts on w2's-360-single charger...
Forced Induction Mopar
  1. Ditch pickle
    Ditch pickle FABO Gold Member FABO Gold Member
    10
    1
    May 18, 2018
    53027
    Local Time:
    3:55 PM
    Anyone out there running something on these lines. This will be my first Mopar build with w2's. I am a little leary about the aluminum offset valve train does it stand up or do they like to pound out?? I am a newbe here any insight will be well received. 360 max 12 lbs of boost/ water injection very streetable more medium build motor. My father has turbocharged his 360,340 and twins on his 440 but never with w2's. I heard they are there own animal... Thanks guys...
  2. rumblefish360
    rumblefish360 so close yet so far away
    34,092
    6015
    Jun 21, 2005
    New York, on a Island
    Local Time:
    4:55 PM
    Sorry, “Valve train pound out?”
    There safe a few very good companies out there for W2’s rocker arms and hardware.
    Harland Sharp
    TD
    Crowed
    Jesel
    to name a few.
    • Agree Agree x 1
    • rumblefish360
      34,092
      6015
      Jun 21, 2005
      Local Time:
      4:55 PM
      Oh! Welcome aboard!
      • Agree Agree x 1
      • Ditch pickle
        10
        1
        May 18, 2018
        53027
        Local Time:
        3:55 PM
        So it's quality stuff. I tend to overbuild everything I touch. Comes from being a farmer. Is one more preffered to the other? Cost doesn't bother me because I'm not doing this to save money. The other question i have is what about the new w2 heads are they decent quality or China junk??
      • 72Dart6pack
        72Dart6pack Harder Better Faster Stronger.
        2,873
        1903
        Feb 1, 2016
        Roseville Michigan
        Local Time:
        4:55 PM
        Go big block.
      • rumblefish360
        34,092
        6015
        Jun 21, 2005
        Local Time:
        4:55 PM
        LMAO, so sez the 6 pack small block guy!
        TD would be about they top of the heap and what MoPar recommends. Look up “B3 racing” for geometry correction kits to get the best possible out come from any set up you use.
        The best in car fitting header would be TTI. Thick flanges and excellent fit. Expensive but worth it. Made by a MoPar guy for MoPar people because normal header companies SUCK!
        He also designs full exhaust kits with straight true duals, H or X pipes in 2-1/2 or 3 inches with Dynomax Super Turbo’s or without mufflers.
        Of course there is also still Hedman for other options.
        • Agree Agree x 1
        • Hellrats
          Hellrats Still wrenching after all these years FABO Gold Member
          907
          644
          Jan 24, 2012
          N.E. Ohio
          Local Time:
          4:55 PM
          I have been running a set of W2 heads on the street for about 15 years now. That was after I used them in a race car for a few years. Mine are the early W2 Econo heads. I have never broken a rocker. I ran Jesel 1.6 aluminum rockers on the race car and then used them when I upgraded to the W5 heads. Well into the 7000 RPM range in the race car. The street W2 heads I have right now have the blue Mopar Performance 1.5 aluminum rockers. I think Crane made them for Mopar and have been discontinued as far as I know. They are a little different to set up but I have never heard of "Valve train pound out". You do have to make sure you use the correct rocker arms and shafts, and make sure they are oiling correctly. They are awesome street cars heads too. Stuff is not cheap that's for sure.
          • Like Like x 1
          • Hellrats
            907
            644
            Jan 24, 2012
            N.E. Ohio
            Local Time:
            4:55 PM
            rumblefish is right. I forgot about the exhaust.... that's sucks big time. But it can be done with lots more money.
          • Hellrats
            907
            644
            Jan 24, 2012
            N.E. Ohio
            Local Time:
            4:55 PM
            You will need the correct intake manifold as well. Not the same as a LA
          • Hellrats
            907
            644
            Jan 24, 2012
            N.E. Ohio
            Local Time:
            4:55 PM
            W2 Econo heads with Mopar Performance rockers. They have a lot of miles on them too.
            • Like Like x 2
            • cpearce
              cpearce Well-Known Member
              639
              250
              Sep 1, 2010
              Edson
              Local Time:
              3:55 PM
              I run W2 with Harland Sharp rockers, no issues. A word of wisdom I learned early in life, buy it right the first time, or you'll buy it twice. Expensive parts dont seem so expensive when they last.
              • Agree Agree x 3
              • Ditch pickle
                10
                1
                May 18, 2018
                53027
                Local Time:
                3:55 PM
                Agree 100 Percent cpearce. I can tig up most of the exhaust I have an endless supply of 404 stainless, elbows, pipes and whatnot. Next question where beside jegs or summit for new w2's. I don't like buying used heads just my opinion. Thanks for all the info so far...!
              • rumblefish360
                34,092
                6015
                Jun 21, 2005
                Local Time:
                4:55 PM
                Goggle W2 for sale and you’ll find a bunch of choices but do ask before you make a purchase.
                Monicatti (sp?) has good prices. But keep checking around.
              • cpearce
                639
                250
                Sep 1, 2010
                Edson
                Local Time:
                3:55 PM
                Try your local Chrysler dealer, you wont regret using W2 heads.
              • Ditch pickle
                10
                1
                May 18, 2018
                53027
                Local Time:
                3:55 PM
                O good call. I don't want to say down the road I wish I would have...
              • Ditch pickle
                10
                1
                May 18, 2018
                53027
                Local Time:
                3:55 PM
              • Ditch pickle
                10
                1
                May 18, 2018
                53027
                Local Time:
                3:55 PM
                That is a work of art.
              • Hellrats
                907
                644
                Jan 24, 2012
                N.E. Ohio
                Local Time:
                4:55 PM
                Thanks. I wish I could have a see through engine so you could see where all the money is. LOL. Fun stuff once you get it right.
              • Ditch pickle
                10
                1
                May 18, 2018
                53027
                Local Time:
                3:55 PM
              • turbodart68
                turbodart68 Well-Known Member
                1,430
                477
                Jul 22, 2009
                Cowan heights, California
                Local Time:
                1:55 PM
                Did I miss something? W2s haven't been made in decades. Welcome by the way. Depending on your intended RPM and spring pressures will decide on which rockers you will buy. On my street stuff I have used Crane golds for years and they work great. For my latest all out twin turbo W5 build I went with Jesel and I have to say that they are a work of art.
              • cpearce
                639
                250
                Sep 1, 2010
                Edson
                Local Time:
                3:55 PM
                W2 heads are still made
              • rumblefish360
                34,092
                6015
                Jun 21, 2005
                Local Time:
                4:55 PM
                There still advertised for sale in standard and 48*.
                Hey just got mine a few months ago.
                W5’s have not been made in a long time but brand new never used sets pop up every now and again. If fact, there is a 2 pair for sale right now in the classified section.
              • turbodart68
                1,430
                477
                Jul 22, 2009
                Local Time:
                1:55 PM
                No kidding? Damn.
              • Ditch pickle
                10
                1
                May 18, 2018
                53027
                Local Time:
                3:55 PM
