Throttle cable question
jack colv
Pa
working on 1973 Plymouth Duster 340 using a avs Carb. off a 1971 340 I have no cable anyone have any idea what for cable I can use Thanks
You should use a cable for a "73" 340 Duster. If you are running an automatic trans, you will also need to address the kickdown system. 1971 used a TQ carb, so your AVS should be from 1968-1970. What are the numbers on the carb?
Thanks for getting back , the carb I am using AVS #4933S My problem no one list a cable for a 1973 duster only up to 1972 and I do not have the one from the car I am running a 4 speed
Yes, they changed in 73 up, at the mounting from round to square? I think. I'll try to check later.
