Cope
Fusing with fire
Hi folks, Just got the 71 318 904 Dart running and cant seem to get my kickdown working.
I have extended the rod from manifold bell crank to tranny bell crank by 1 5/8". (the difference in old carb linkage height VS new)
I do have some kickdown but its verry minor and late.
I have read the factory service manual section on kickdow adjustment and have zero slop in linkage at WOT.
Take a look and tell me what you think.
Kickdown with drop base cleaner removed. Note how far forward the rod is.
In this pick is about where the linkage sits with the drop base air cleaner on.
Im thinking of cutting the section of "slot" off that is behing the carb throttle arm in the first pick and welding it on nice and short. Do I need that section behind the arm?
Is the fact that my linkage is pushed so far back with the aircleaner on why I have hardly any kickdown and its way late to come in?
Thanks again for the time and advice.
