Tie rod ends hitting torsion bars
I'd swap the zerk for a flush type and get an adapter to standard (so you don't need to switch fittings on the grease gun just for these). For the tierod body clearance, it looks like (based on advertised tie rod specs) the taper may be 1.5"/foot (a common size reamer) and could be reamed to lower the inner tie rods into the center link a little deeper (talk to a machinist or mech engineer with parts in hand).
Watch that it doesn't get too deep or the nut will bottom on the taper before the taper is properly seated
Yes, I know, but still not a deal breaker. A hardened washer can be added, but there is more to it than that, which is why I said "talk" and not go for it.
He could also fit 1/2 inch rod ends and a bolt with a taper insert, but I'd rather have the tie rod for longevity.
