Chuck Bushey
Active Member
I've been working on my 66 barracuda 273 now for 20 years. I hired a reputable guy to check out the engine and bring it up to snuff. I've had it back now for 7+ years and have finally gotten it back in the car. However, much to my dismay it has a coolant leak out the timing chain cover. Investigation proved that it was not the original cover put back on (seems it's a late model cover) and after removing it found it was warped. So I am looking for an early model 273 cover to replace it. Does anyone know where I might find one? (the guy who went through mine is retired and no longer around). I also found that the Oil Slinger was hacked up in order to fit the new cover and so I need to locate another one of those as well.
I also have another related question - there are no locating pins in the engine or the cover, how was this cover supposed to have been located to ensure proper centering so as to not prematurely wear out the crank seal? The service manual does not mention this but I believe there had to be something that made sure this was properly centered.
